Trunk adjustment, One side higher than other |
Robarabian |
Jan 25 2022, 10:37 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
How do I adjust this so it is even. The hinges all work great and are not cracked / fractured. After my repaint I mounted everything but one side is off.
Is it the adjustment of the hinge hardware (all the little brackets / washers?) Any help is appreciated. |
Superhawk996 |
Jan 26 2022, 02:49 PM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Could be a lot going on there.
Assuming trunk hinges are in the right location . . . does it fit better with a gentle twist? Hard to tell from picture is this all lined up along all other sides but this is just excessive gap in Z height? Do you have the seals in there? Is one side seal sitting tall, holding up the right side? Not sure what you mean by "all the little brackets". The little 2nd leg that extends down to the wheelhouse doesn't control Z height. Did it fit properly before paint? |
Lo-Fi Version | Time is now: 17th May 2024 - 05:09 PM |
