New JWest Product, Question regarding use… |
jim_hoyland |
Jan 26 2022, 02:26 PM
Get that VIN ? Group: Members Posts: 9,270 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Where is this installed?
NEW! Shift Rod Support Bracket from JWest Attached thumbnail(s) |
SirAndy |
Jan 26 2022, 02:32 PM
Resident German Group: Admin Posts: 41,610 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The full version (not mobile) has the following description:
QUOTE Replacement/upgraded bracket that holds the shift rod bushing under the shifter Fits 911 '65-'86, all 912, 930 through '88, 914 with tail-shift, and 914/6 '70-'72 Replaces factory part 930-424-031-01 and 914-424-224-00 Includes new rod bushing installed Machined aluminum and black anodized Design grips bushings tighter than the factory part for a better fit to shift rod, yet large radius in bushing hole allows for easier replacement of the bushing. Utilizes factory bushing 914-424-224-00 (included) Upgrade for '65-'69 911 (replaces early "narrow" shift bushing) |
Mark Henry |
Jan 26 2022, 02:37 PM
It bolts on "upside down" just under the rear of the shifter, in the tunnel.
Steve |
Jan 26 2022, 03:02 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Unless i am reading this wrong, this upgrade is only for tail shifter 914-4, 914-6 and 914's like mine with a 915 gear box. Not for 914's with a side shifter (73-76).
jim_hoyland |
Jan 26 2022, 03:49 PM
bdstone914 |
Jan 26 2022, 03:51 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket.
NARP74 |
Jan 26 2022, 03:56 PM
Senior Member Group: Members Posts: 1,055 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
The holes are on the other side, in a different pic.
https://www.jwestengineering.com/NEW-Shift-...acket_p_42.html |
jim_hoyland |
Jan 26 2022, 04:55 PM
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket. Is this mounted at the rear console or in cabin area ? Wher would I look to see if I have one.? |
Steve |
Jan 26 2022, 05:02 PM
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket. Is this mounted at the rear console or in cabin area ? Wher would I look to see if I have one.? Let me find the diagram, but since your car is a 73-76 side shifter, you don't have one. |
Steve |
Jan 26 2022, 05:09 PM
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket. Is this mounted at the rear console or in cabin area ? Wher would I look to see if I have one.? Let me find the diagram, but since your car is a 73-76 side shifter, you don't have one. This replaces item 14. Only for 72 and older 914's. |
jim_hoyland |
Jan 26 2022, 06:06 PM
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket. Is this mounted at the rear console or in cabin area ? Wher would I look to see if I have one.? Let me find the diagram, but since your car is a 73-76 side shifter, you don't have one. Thanks. Got it ! (IMG:style_emoticons/default/smile.gif) |
SirAndy |
Jan 26 2022, 06:59 PM
Is this mounted at the rear console or in cabin area ? Wher would I look to see if I have one.? From their website description: "Replacement/upgraded bracket that holds the shift rod bushing under the shifter" (IMG:style_emoticons/default/shades.gif) |
76-914 |
Jan 26 2022, 11:10 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Jim, have you looked at Chris', aka Tangerine Racing's, latest shift rod improvement?
rgalla9146 |
Jan 27 2022, 06:08 AM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The big market for this is 911s from '72 to '89
Anything with a 915 or.......916 ! |
jim_hoyland |
Jan 27 2022, 06:26 AM
Lo-Fi Version | Time is now: 2nd May 2024 - 04:05 PM |
