New JWest Product, Question regarding useā¦ |
jim_hoyland |
Jan 26 2022, 02:26 PM
Get that VIN ? Group: Members Posts: 9,298 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Where is this installed?
NEW! Shift Rod Support Bracket from JWest Attached thumbnail(s) |
bdstone914 |
Jan 26 2022, 03:51 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket.
jim_hoyland |
Jan 26 2022, 04:55 PM
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket. Is this mounted at the rear console or in cabin area ? Wher would I look to see if I have one.? |
Steve |
Jan 26 2022, 05:02 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket. Is this mounted at the rear console or in cabin area ? Wher would I look to see if I have one.? Let me find the diagram, but since your car is a 73-76 side shifter, you don't have one. |
jim_hoyland |
Jan 26 2022, 06:06 PM
Cant see the point of it. No problem with the original bracket. And it does not have the correct two threaded holes for attachment to the 914 tail shift shifter bracket. Is this mounted at the rear console or in cabin area ? Wher would I look to see if I have one.? Let me find the diagram, but since your car is a 73-76 side shifter, you don't have one. Thanks. Got it ! (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:28 AM |
