WTB 12-pole connector, Porsche Part #91161212103 |
914sgofast2 |
Feb 4 2022, 02:56 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Looking to buy a good used plastic 12-pole connector (male end) used on the turn signal & ignition wiring harness on early 1970 and 1971 model year 914s. Mine broke into a dozen pieces. It hooks into the female 12-pole connector under the dashboard.
This is the black plastic rectangular connector used on the end of the wiring harness coming from the turn signal and ignition switch wiring harness in the steering column. (Only the female end of the 12-pole connector is available from Porsche now) Thanks. Mike D. |
bdstone914 |
Feb 4 2022, 05:04 PM
Looking to buy a good used plastic 12-pole connector (male end) used on the turn signal & ignition wiring harness on early 1970 and 1971 model year 914s. Mine broke into a dozen pieces. It hooks into the female 12-pole connector under the dashboard. This is the black plastic rectangular connector used on the end of the wiring harness coming from the turn signal and ignition switch wiring harness in the steering column. (Only the female end of the 12-pole connector is available from Porsche now) Thanks. Mike D. Pretty sure i have one. Will check soon. |
914sgofast2 |
Feb 4 2022, 06:28 PM
Thanks! I will buy the whole turn signal switch with harness if necessary.
Lo-Fi Version | Time is now: 19th May 2024 - 10:54 AM |
