Rear brake caliper question, outer adjuster appears to be leaking, will not tighten to set clearance |
DRPHIL914 |
Feb 21 2022, 04:06 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
my calipers were all fully restored by PMB performance around
5 years ago of so, when we did all new hard and soft lines. The whole system was replaced then, and i check and set clearance yearly. last year i had to do a new master cylinder so i did that ans set the clearance right before Werks Reunion last May. now it’s time again and i noticed when i pulled the wheel there is a very small amount of fluid leakage around that outer adjuster, and after i loosened the lock but i turned the inter adjuster but it didn’t tighten up the pad at all it just spins! there is way too much space there and it needs to be in quite a bit. any thoughts here? am i going to need to send this in? @EricShea Attached thumbnail(s) |
Lo-Fi Version | Time is now: 26th May 2024 - 01:47 PM |
