Red wire with some crispy insulation.... |
advman89 |
Feb 28 2022, 09:09 PM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
I'm in the depths of a full dash replacement and I'm need to figure out a situation.
I have a couple things to address. FUSE 11 (Hazard / Interior Light) has never worked-dead short immediately. I thought I remember someone saying that I need to look at the ground under the passenger seat and the passenger door switch as possible issues there. But I also have a some weirdness with the Hazard too... There is a new square relay installed and some wires cut in from the factory hazard switcher. The turn signals are all working, but I need to get the hazards operational. And on top of that, I discovered this red wire, long melted...will splice in a new wire, but thought the group might be able to point me in a direction. I know I have a color wiring chart...off to the archives for it to start looking for things. |
914sgofast2 |
Feb 28 2022, 09:13 PM
Senior Member Group: Members Posts: 613 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
You have my sympathy. I am trying to sort out the turn signal and hazard light wiring on my 1970. The wiring diagrams in the Haynes book are virtually worthless. That said, a red wire is usually a “hot” wire from somewhere; it’s never a ground wire. All ground wires are brown.
VaccaRabite |
Feb 28 2022, 09:28 PM
En Garde! Group: Admin Posts: 13,419 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Big red wire is either going from the ignition switch to the starter motor, or the battery to the ignition switch. It carries a lot of current, and many of us have changed things around to use a ford solenoid to shunt the big current from the battery direct to the starter motor instead of routing it through the ignition switch.
Zach |
Costa05 |
Feb 28 2022, 10:48 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
I'm in the depths of a full dash replacement and I'm need to figure out a situation. I have a couple things to address. FUSE 11 (Hazard / Interior Light) has never worked-dead short immediately. I thought I remember someone saying that I need to look at the ground under the passenger seat and the passenger door switch as possible issues there. But I also have a some weirdness with the Hazard too... There is a new square relay installed and some wires cut in from the factory hazard switcher. The turn signals are all working, but I need to get the hazards operational. And on top of that, I discovered this red wire, long melted...will splice in a new wire, but thought the group might be able to point me in a direction. I know I have a color wiring chart...off to the archives for it to start looking for things. One thought, as one who is learning more an more all the time about the engineering behind these cars, (nerdly including Haynes book wiring diagrams), it appears at first glance to me that red wire may be the constant 12v input side to the ignition switch directly from battery terminal block (Haynes). Big yellow one would be the starter wire headed back to the starter through the 14 pin connector on your relay board in the engine bay. Others can correct me but this red wire in question Is not fused from the factory which leaves it at risk of failure. One of the bad designs on these cars as others discovered. |
barnfind9141972 |
Mar 1 2022, 03:46 AM
Member Group: Members Posts: 100 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California |
What year is it? I have a 72-73 diagram that’s awesome and easy to read. I can snap pictures if it’s the right years
Spoke |
Mar 1 2022, 04:48 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
About the blue/white wire shorted to the brown wire on the flasher, likely the flasher installed does not drive the K/C2 pin as the OEM flasher did so the PO shorted the blue/white wire to brown wire basically shorting K/C2 to ground which is what I do for the EP26 LED-compatible flasher as shown below.
It could be too that the flasher installed only has 3 pins and doesn't have the K/C2 pin at all. If the Left and Right turnsignals work, then the flashers will work too as long as the flasher switch is functional. For that burned red wire, at some point the wire tried to pretend to be a fuse but looks like it failed as a fuse and just melted the insulation. If you wanted to remove that wire from service, find out where it starts and ends and just add a new wire and leave the original wire in the loop as it would be nearly impossible to remove the old wire. |
Superhawk996 |
Mar 1 2022, 07:25 AM
914 Guru Group: Members Posts: 5,724 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If you wanted to remove that wire from service, find out where it starts and ends and just add a new wire and leave the original wire in the loop as it would be nearly impossible to remove the old wire. I usually agree with @Spoke 100% but I would simply cut the cloth harness wrap, then remove the offending melted segment. The reason is that when a wire melts this badly, it often melts adjacent wires in the harness which can lead to random shorts later on. At best some of the adjacent wires simply have melted but compromised insulation. I do get there is a theory that if there is no short there, leave well enough alone. That isn't the way I was trained as a electronics tech. I'd fish out the melted red one (and any other adjacent wires that have melted insulation), and splice in a new section then re-wrap the harness. I think 914Rubber even sells cloth harness tape. If they don't it's widely available at other electrical supply houses. I would also go back and get rid of the stupid quick splice connectors - those things are junk. Whenever I see those I immediately know the quality of the workmanship that has been done prior. Finally, you need to find root cause of what caused the red wire to short in the 1st place before replacing the melted segment unless you wish to do the whole thing over again in the future should it decide to short again. |
advman89 |
Mar 1 2022, 09:13 AM
Thank you all for the replies.
The Car is a 1971 with a 2.0L The starter was upgraded by the PO. I'll start tracking it back and see where it goes, but I'm afraid of pulling the whole harness. I'll see what I find and report back. |
advman89 |
Mar 1 2022, 11:33 PM
Gotcha. Check this out! Opened the connector from the middle of the dash, pulled pin 1 Main Supply. Rest of wiring looks good. Carefully unwrapped the original, coaxed the wire free...bit by bit back to the main above the fuse panel. I inspected the wire and found no breaks, surprisingly. Replacing the red wire proper and rewrapping. (my Harness tape has disappeared! Dammit!!) Question--should I put a fuse in that line? If so, what size? Next up...hazards. Thanks all. |
Superhawk996 |
Mar 2 2022, 06:57 AM
(IMG:style_emoticons/default/smilie_pokal.gif) Nice job getting that out of there. Hopefully, you didn't find other wires adjacent to this one melted?
Before you power up your new repair, did you find root cause of what caused the melting? Before you power it up again, you can use a Digital Multi Meter to very you don't have some sort of short still present. I went back to OP and I'm not exactly sure what this red wire is. Is this the red feed to the flasher that Spoke posted (feed from fuse#8)or is this another circuit? Or, is it associated with Fuse #11 that you previously said has some sort of short? There a a couple of red feed wires direct from the battery to fuse #11 was it one of these? Before the question of whether it can be fused, you would need to know what circuit it was and how much amperage it is expected to draw. Power from Battery? Power feed to ignition switch for starter solenoid? Power feed to buzzer? |
advman89 |
Mar 2 2022, 08:21 AM
I checked all the adjacent wires and there are no breaks.
The wire comes from the main supply near the fuse panel and is the supply for the plug near the middle of the dash (you can see a pic of that in the first posts). I know the ignition was swapped at some point by the PO and nothing was secured well when I got it. I am speculating that there might have been a opening in the wire and it shorted under the dash. I've looked everything else over and can't find any evidence of any further melting. As for my Fuse 11 issue...haven't sorted that yet. This wire wasn't connected to the fuse panel. |
Superhawk996 |
Mar 2 2022, 08:48 AM
I checked all the adjacent wires and there are no breaks. The wire comes from the main supply near the fuse panel and is the supply for the plug near the middle of the dash (you can see a pic of that in the first posts). I know the ignition was swapped at some point by the PO and nothing was secured well when I got it. I am speculating that there might have been a opening in the wire and it shorted under the dash. I've looked everything else over and can't find any evidence of any further melting. As for my Fuse 11 issue...haven't sorted that yet. This wire wasn't connected to the fuse panel. I'm a dope because I can't visualize your exact setup and what you mean by main supply. I've only owned 73's. and have to work via schematics. I'll go look at my harness to see if I can better understand which part that melted red wire is coming out of. I checked all the adjacent wires and there are no breaks. -- Good job! (IMG:style_emoticons/default/smilie_pokal.gif) I am speculating that there might have been a opening in the wire and it shorted under the dash. For what it's worth, that wire didn't melt like that from some minor short like a small nick in the insulation. That was large short that drew lots of current, for a pretty significant length of time, and made lots of smoke. Would seem like the source would be sort of obvious but who knows what may have been done in the past and then ignored. Keep posting your progress and what other symptoms you find. |
advman89 |
Mar 2 2022, 12:27 PM
Here are some photos...
PIN 12 (depending on diagram--some say Pin 1)- Supply. That connection goes to the ignition (I believe). That was replaced by the PO at some point in it's history. The connection goes from there to the connection by the fuse panel. I had to cut the wire to get factory connector off (eyelet style)--the second bare wire there was also connected to the same wire, but didn't suffer the same melt. I am very keen on burning electrical smells...and I've never once smelled anything "burning" in the car. Dad was in avionics and my other hobby is old audio equipment...so it's in my genes to suss out bad wiring, I guess! |
Superhawk996 |
Mar 2 2022, 02:01 PM
I'm out of my league based on the photos because I'm still not making heads of tails of it to get myself oriented to what circuit you're working on.
I don't think there are major changes between 72 wiring and 73 like I'm seeing in photos. I just looked at my harness and the only place I have a 12 pin connector like that is out in the engine compartment that goes to/from the relay board. (IMG:style_emoticons/default/confused24.gif) Also on the left side of what I think is the fuse panel mount, I have nothing like what you have on there clipped or screwed to the fuse panel support bracket (thing with the screw). My fuse block left side bracket only has a ground stud. Yours has some sort of other arrangement back there with the screw & arrow is that what the red wire was attached to? (IMG:style_emoticons/default/confused24.gif) |
advman89 |
Mar 2 2022, 03:55 PM
Superhawk996 |
Mar 2 2022, 04:02 PM
is this a 914-6?
ejm |
Mar 2 2022, 05:44 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,688 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
914sgofast2 |
Mar 2 2022, 05:54 PM
Mine is a 71. I don't know if there are a lot of difference> The multi-pin plug supports the ignition now. Looks factory and I'm not seeing any splices. It "slots" into a place on the inside of the lower dash. I can't find it here either.... I am going through a similar problem. The problem with the wiring diagrams is that they don't show the two sides of the 12 pin connectors and how the wires connect to them. The colors coming out of the ignition switch wiring and turn signal switch wiring on the early cars (1970-1971) are NOT the same on both ends of the 12-pin connector! Porsche used one set of colors on the female side wiring and another set of colors on the male side wiring of the connector. That must be why the posts were numbered on the 12-post connectors. It makes for very frustrating trouble-shooting. |
Costa05 |
Mar 2 2022, 05:59 PM
QUOTE(advman89) I have a 73 and dont have that screw post connection either. It looks like the PO installed a terminal block to make the spliced connection of two wires at that spot. Eyelet to eyelet. Likely trying to repair a problem, and the problem still exists evident of the melted wire. I would probably break out a continuity tester and voltmeter to confirm where it goes and what was its purpose. If by any chance it passes through the ignition switch, then knowing first hand that 914 ignition switches are super cheaply made, and high failure rate, I would put that as a potential shorting out location. A quick test would be seeing if you have continuity of the red wires to a ground location point. Battery disconnected. Test continuity in both key off, key on, and key start positions. If you discover continuity at all with test then you narrowed down your problem further. Best of luck. |
barefoot |
Mar 3 2022, 07:39 AM
Senior Member Group: Members Posts: 1,268 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I had to install a complete replacement harness in my 76 & decided to fuze everything as there were problems with the old harness.
Installed a 1 in 4 out fuze block near the battery for the 4 red wires coming off the battery. Fuzed with 2- 25 amp & 2- 10 amp fuzes. Now I sleep well (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 19th April 2024 - 12:41 AM |
