Red wire with some crispy insulation.... |
advman89 |
Feb 28 2022, 09:09 PM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
I'm in the depths of a full dash replacement and I'm need to figure out a situation.
I have a couple things to address. FUSE 11 (Hazard / Interior Light) has never worked-dead short immediately. I thought I remember someone saying that I need to look at the ground under the passenger seat and the passenger door switch as possible issues there. But I also have a some weirdness with the Hazard too... There is a new square relay installed and some wires cut in from the factory hazard switcher. The turn signals are all working, but I need to get the hazards operational. And on top of that, I discovered this red wire, long melted...will splice in a new wire, but thought the group might be able to point me in a direction. I know I have a color wiring chart...off to the archives for it to start looking for things. |
Superhawk996 |
Mar 2 2022, 06:57 AM
914 Guru Group: Members Posts: 5,822 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/smilie_pokal.gif) Nice job getting that out of there. Hopefully, you didn't find other wires adjacent to this one melted?
Before you power up your new repair, did you find root cause of what caused the melting? Before you power it up again, you can use a Digital Multi Meter to very you don't have some sort of short still present. I went back to OP and I'm not exactly sure what this red wire is. Is this the red feed to the flasher that Spoke posted (feed from fuse#8)or is this another circuit? Or, is it associated with Fuse #11 that you previously said has some sort of short? There a a couple of red feed wires direct from the battery to fuse #11 was it one of these? Before the question of whether it can be fused, you would need to know what circuit it was and how much amperage it is expected to draw. Power from Battery? Power feed to ignition switch for starter solenoid? Power feed to buzzer? |
Lo-Fi Version | Time is now: 16th May 2024 - 12:30 PM |
