Red wire with some crispy insulation.... |
advman89 |
Feb 28 2022, 09:09 PM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
I'm in the depths of a full dash replacement and I'm need to figure out a situation.
I have a couple things to address. FUSE 11 (Hazard / Interior Light) has never worked-dead short immediately. I thought I remember someone saying that I need to look at the ground under the passenger seat and the passenger door switch as possible issues there. But I also have a some weirdness with the Hazard too... There is a new square relay installed and some wires cut in from the factory hazard switcher. The turn signals are all working, but I need to get the hazards operational. And on top of that, I discovered this red wire, long melted...will splice in a new wire, but thought the group might be able to point me in a direction. I know I have a color wiring chart...off to the archives for it to start looking for things. |
Superhawk996 |
Mar 2 2022, 02:01 PM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I'm out of my league based on the photos because I'm still not making heads of tails of it to get myself oriented to what circuit you're working on.
I don't think there are major changes between 72 wiring and 73 like I'm seeing in photos. I just looked at my harness and the only place I have a 12 pin connector like that is out in the engine compartment that goes to/from the relay board. (IMG:style_emoticons/default/confused24.gif) Also on the left side of what I think is the fuse panel mount, I have nothing like what you have on there clipped or screwed to the fuse panel support bracket (thing with the screw). My fuse block left side bracket only has a ground stud. Yours has some sort of other arrangement back there with the screw & arrow is that what the red wire was attached to? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 12:20 AM |
