Red wire with some crispy insulation.... |
advman89 |
Feb 28 2022, 09:09 PM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
I'm in the depths of a full dash replacement and I'm need to figure out a situation.
I have a couple things to address. FUSE 11 (Hazard / Interior Light) has never worked-dead short immediately. I thought I remember someone saying that I need to look at the ground under the passenger seat and the passenger door switch as possible issues there. But I also have a some weirdness with the Hazard too... There is a new square relay installed and some wires cut in from the factory hazard switcher. The turn signals are all working, but I need to get the hazards operational. And on top of that, I discovered this red wire, long melted...will splice in a new wire, but thought the group might be able to point me in a direction. I know I have a color wiring chart...off to the archives for it to start looking for things. |
anderssj |
Mar 3 2022, 07:43 PM
Dog is my copilot... Group: Members Posts: 1,656 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
That power distribution block is there on my '72... and it was both unfused and always "hot." I've since put a fuse box in for the 3-4 red wires at the battery.
We had a similar problem on my car back in 2004 (IMG:style_emoticons/default/blink.gif) We were out for a drive, hit a bump and smoke started coming out from under the dash. Fortunately it quit when I shut things off--and we were only about a mile from home. The problem appeared to be caused by the front/ upper edge of the fuse panel/tray cutting through the insulation on one or more wires leading from/to the fuses. These wires looked like they had been resting on this relatively sharp edge since the car was built. I've since covered the tray edges with some plastic welting (like small weather-strip), so that should end it--but you may want to check on yours. Hope this helps! |
Lo-Fi Version | Time is now: 16th May 2024 - 01:18 PM |
