Red wire with some crispy insulation.... |
advman89 |
Feb 28 2022, 09:09 PM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
I'm in the depths of a full dash replacement and I'm need to figure out a situation.
I have a couple things to address. FUSE 11 (Hazard / Interior Light) has never worked-dead short immediately. I thought I remember someone saying that I need to look at the ground under the passenger seat and the passenger door switch as possible issues there. But I also have a some weirdness with the Hazard too... There is a new square relay installed and some wires cut in from the factory hazard switcher. The turn signals are all working, but I need to get the hazards operational. And on top of that, I discovered this red wire, long melted...will splice in a new wire, but thought the group might be able to point me in a direction. I know I have a color wiring chart...off to the archives for it to start looking for things. |
advman89 |
Mar 4 2022, 08:50 AM
The ground block was removed last night, wires properly soldered together. Fuse block will get installed once the Great and Almighty Bezos delivers it.
Harness is re-tapped with the good stuff. I've been keeping a good eye out for sharp edges. Next up--Let's tackle that switcher and hazard wiring nightmare... Thank you all!! |
Lo-Fi Version | Time is now: 16th May 2024 - 03:21 AM |
