Red wire with some crispy insulation.... |
advman89 |
Feb 28 2022, 09:09 PM
Member Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest |
I'm in the depths of a full dash replacement and I'm need to figure out a situation.
I have a couple things to address. FUSE 11 (Hazard / Interior Light) has never worked-dead short immediately. I thought I remember someone saying that I need to look at the ground under the passenger seat and the passenger door switch as possible issues there. But I also have a some weirdness with the Hazard too... There is a new square relay installed and some wires cut in from the factory hazard switcher. The turn signals are all working, but I need to get the hazards operational. And on top of that, I discovered this red wire, long melted...will splice in a new wire, but thought the group might be able to point me in a direction. I know I have a color wiring chart...off to the archives for it to start looking for things. |
advman89 |
Mar 14 2022, 12:19 PM
Fuse block is in place. I feel better. Thank you all!
I'm still trying to sort out the Fuse 11. It's no longer shorting....but interior light still isn't working--no power. Hazard switch_ Turn signals are working, but if you pull the hazards, the turn signals no longer work. I have tried two different hazards with the same result. Any thoughts? |
VaccaRabite |
Mar 16 2022, 12:00 PM
En Garde! Group: Admin Posts: 13,443 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Fuse block is in place. I feel better. Thank you all! I'm still trying to sort out the Fuse 11. It's no longer shorting....but interior light still isn't working--no power. Hazard switch_ Turn signals are working, but if you pull the hazards, the turn signals no longer work. I have tried two different hazards with the same result. Any thoughts? That's not a bug, that's a feature. The hazard flashers and turn signals are the same bulbs. I don't think you can use both at the same time. I could be wrong, but I think the flashers take priority. For the interior light check continuity from the fuse panel to the hot lead at the light. and then check continuity from the light back to ground. One of those wires likely has a break. Zach |
ClayPerrine |
Mar 16 2022, 02:26 PM
Life's been good to me so far..... Group: Admin Posts: 15,463 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Fuse block is in place. I feel better. Thank you all! I'm still trying to sort out the Fuse 11. It's no longer shorting....but interior light still isn't working--no power. Hazard switch_ Turn signals are working, but if you pull the hazards, the turn signals no longer work. I have tried two different hazards with the same result. Any thoughts? That's not a bug, that's a feature. The hazard flashers and turn signals are the same bulbs. I don't think you can use both at the same time. I could be wrong, but I think the flashers take priority. For the interior light check continuity from the fuse panel to the hot lead at the light. and then check continuity from the light back to ground. One of those wires likely has a break. Zach (IMG:style_emoticons/default/agree.gif) When you pull the hazard flasher switch, all it is doing is turning on the turn signals on both sides at the same time. It completely bypasses the turn signal switch. |
Lo-Fi Version | Time is now: 16th May 2024 - 04:36 AM |
