Think this cracked wheel can be fixed? |
Tdskip |
Mar 1 2022, 02:07 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
BillJ |
Mar 1 2022, 02:08 PM
Senior Member Group: Members Posts: 1,098 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Can a cast wheel like the cookie cutter be welded reliably?
Mar 1 2022, 02:09 PM
Resident German Group: Admin Posts: 41,642 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What do you all think? Someone who does this sort of thing for a living could probably weld this up correctly. (IMG:style_emoticons/default/idea.gif) |
Mar 1 2022, 02:25 PM
914-6 GT in waiting Group: Members Posts: 19,273 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
@MB911
Ben can probably advise you. |
Van B |
Mar 1 2022, 02:29 PM
Senior Member Group: Members Posts: 1,586 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
It can be repaired with TIG welding pretty easy. But finishing will either require a smooth hand with a grinder or a lathe to turn it.
I repaired many of my own rims over the years when I raced and the cast aluminum on wheels is not nearly as bad as the cast aluminum on engines. The porosity of cast aluminum actually soaks up the oil and then when you try to weld it all comes out. It can be a mess. But wheels in general are much easier. the weld will still have to be built up, hence the need for clever grinding or turning on a lathe. Edit: Just to say it, that damage was almost certainly caused by rough handling and not by use. Someone was rough with it on a balancer is my bet. |
Chris914n6 |
Mar 1 2022, 02:49 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
That area is not structural. You can just fill it.
ThePaintedMan |
Mar 1 2022, 02:53 PM
Might just be cheaper to replace it. I have an ATS taking up space in my shed that you could have for free if you're willing to pay for shipping. (IMG:style_emoticons/default/beerchug.gif)
Tdskip |
Mar 1 2022, 03:08 PM
Thanks for all of the responses - very much appreciated.
This is a matched set off the ‘73 911T going on to the ‘74 /6 build so will try to save this. Off to a wheel specialist I go. Very much appreciate the help. |
Van B |
Mar 1 2022, 05:18 PM
Might just be cheaper to replace it. I have an ATS taking up space in my shed that you could have for free if you're willing to pay for shipping. (IMG:style_emoticons/default/beerchug.gif) @ThePaintedMan Talk to me about this ATS wheel. Is it the 4 lug 5 spoke? |
dr914@autoatlanta.com |
Mar 1 2022, 05:29 PM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
brant |
Mar 1 2022, 06:25 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
A proper repair will cost about the same as a replacement
euro911 |
Mar 2 2022, 02:14 AM
I've had a couple of bent wheels repaired at a shop in Costa Mesa. They did a great job on both. Unfortunately, I'm having a brain fart remembering their name or address ... I'll look for their business card.
roblav1 |
Mar 2 2022, 07:12 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I'd never run that wheel again. No way! Not for the cost of another cookie cutter. That crack is definitely structural.
Beach914 |
Mar 2 2022, 08:18 AM
Senior Member Group: Members Posts: 966 Joined: 28-March 10 From: Aliso Viejo Member No.: 11,519 Region Association: Southern California |
I've had a couple of bent wheels repaired at a shop in Costa Mesa. They did a great job on both. Unfortunately, I'm having a brain fart remembering their name or address ... I'll look for their business card. Was that WRS ? They rebuilt my HRE 505's a few years ago. |
euro911 |
Mar 2 2022, 10:54 AM
I've had a couple of bent wheels repaired at a shop in Costa Mesa. They did a great job on both. Unfortunately, I'm having a brain fart remembering their name or address ... I'll look for their business card. Was that WRS? They rebuilt my HRE 505's a few years ago. Yes it was, and my goof - they're in Santa Ana. Here's their web site ... https://www.ocwheelrepairs.com/ |
mb911 |
Mar 2 2022, 01:06 PM
914 Guru Group: Members Posts: 6,852 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I'd never run that wheel again. No way! Not for the cost of another cookie cutter. That crack is definitely structural. (IMG:style_emoticons/default/agree.gif) |
Mar 2 2022, 01:15 PM
I'd never run that wheel again. No way! Not for the cost of another cookie cutter. That crack is definitely structural. (IMG:style_emoticons/default/agree.gif) I would have thought an easy fix but if Ben says no, we’ll he is 100x smarter than me about this stuff. Will make a nice clock in the shop. Attached image(s) |
BillJ |
Cookie cutters can be readily had for under a $100. I would find a good one and refinish as you see fit. The matching set thing is only valuable really to original car and matching cookie cutters have no increased value like fuchs do if that is your thought process.
Or. Just go do it because thats what you want! |
Van B |
Mar 2 2022, 01:54 PM
I'd never run that wheel again. No way! Not for the cost of another cookie cutter. That crack is definitely structural. (IMG:style_emoticons/default/agree.gif) Where's the "I disagree" emoji? That wheel was clearly rough handled on a balance machine. Probably got thrown on or pulled off at an angle that caused the steel shaft to bind. You can tell by how the edge was pulled/flared. Further, that part of the wheel carries no more mechanical load than the centrifugal force of the center cap. |
Mar 2 2022, 02:37 PM
I’m also guessing a welder might not want to put their hands on it if there’s a chance after welding it could fail completely and cause an accident. Sometimes you don’t want to be the last person to touch something just to make a couple bucks.
Lo-Fi Version | Time is now: 18th May 2024 - 10:25 AM |
