Perlon backpad question |
jmargush |
Mar 13 2022, 10:24 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am curious to know from those who have done the backpad delete and used perlon to cover the firewall.
Is the perlon flexible(stretchy) enough to conform to the contours or are there still areas where it needs to have triangles cut out of it to accommodate areas where the felt might bunch up? Can it be done in one piece or is it recommended to do a center and side pieces |
Mar 13 2022, 11:03 AM
If you buy the perlon without a backing, it’s stretchy enough to apply without cutting.
GregAmy |
Mar 13 2022, 11:14 AM
Advanced Member Group: Members Posts: 2,302 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
jmargush |
Mar 13 2022, 11:37 AM
thanks
bkrantz |
Mar 13 2022, 09:02 PM
914 Guru Group: Members Posts: 7,766 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
The one I bought (on eBay) have three pieces stitched together along vertical seams that follow either side of the center raised section.
roblav1 |
Mar 13 2022, 09:32 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I did 80% wool felt... from McMaster Carr. Installed in 2 pieces split right down the middle. Much nicer than Perlon and absorbs sound better.
Lo-Fi Version | Time is now: 18th May 2024 - 07:52 AM |
