supplemental fuse box, more better safety for unfused 'hot' wires |
anderssj |
Mar 21 2022, 01:00 PM
Dog is my copilot... Group: Members Posts: 1,660 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
I'm finally getting around to "safetyizing" the three unfused/hot wires at the battery on my 914.
First, a disclaimer: this is on a 1972 car. I think power distribution on earlier cars is similar--but I know there are major wiring changes to the later cars. Always check the appropriate wiring diagrams for your car before any starting work. Disconnecting battery "-"/"ground" is a good idea too. The wires I'm working with are shown here: There are two smaller red wires crimped into the single ring terminal on the left, and a larger single wire/ring terminal on the right. As designed, all three are hot and unfused. (IMG:style_emoticons/default/dry.gif) If I'm reading the wiring diagrams correctly, the two smaller wires go to terminals 12 and 14 on the regulator plate and provide power to heater fan, fuel pump, rear window defogger, etc. Not sure of the total load/power on this circuit... The larger wire on the right goes forward to the power distribution/junction near the fuse box (it's the bake-lite block shown in this picture [ripped off from advman89's earlier thread]): I think the power distribution/junction is the tiny "32" circled in this diagram: From the power distribution/junction, electrical power is distributed through additional unfused/hot wires to the column/ignition switch("26"), headlight switch ("28"), fuses 10, 11, and 12, and other components. Not sure of the total load on this circuit either... As others here have done, I'm planning to install a supplemental fuse box between the battery "+" and these three wires to give myself additional margin of safety/peace of mind... The box I'm planning to use is a Volvo part with a 8ga cable from the battery "+" to a common bus. The box can support a total of four circuits (I'm only going to use two, one for each ring terminal). The box currently has 40 amp fuses. I don't think any drilling or cutting will be needed, so I will be able to put the car back into original configuration in a few minutes. Does anyone know the total load on these circuits? Given that alternator output is only 50 amps, I figure that new 40 amp replacement fuses for the ones shown in the box should be fine...but thought I should ask the folks here. Thanks in advance for any advice, insights, and BTDTs! (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 04:38 PM |
