> L-Jet going full Rich on Deceleration
Brian Fuerbach
post Mar 27 2022, 06:36 PM
1974 1.8 with L- jet. Been playing with a wide band air fuel meter and noticed that when I lift the throttle the AFR goes to max value on the gauge. I thought it was supposed to go lean. I checked the throttle position switch and it checks out fine. Going to check the wiring harness next.
What else should I check? Decel valve?
Brian Fuerbach   L-Jet going full Rich on Deceleration   Mar 27 2022, 06:36 PM
emerygt350   My mustang goes super lean on throttle lift, as it...   Mar 27 2022, 06:44 PM
Van B   I haven’t measured my AFR to compare so, I canâ€...   Mar 27 2022, 07:19 PM
Brian Fuerbach   I haven’t measured my AFR to compare so, I canâ...   Mar 27 2022, 09:50 PM
Van B   Ok so, two thoughts: 1.) set your decel valve to ...   Mar 27 2022, 10:04 PM
Brian Fuerbach   Ok so, two thoughts: 1.) set your decel valve to...   Mar 27 2022, 10:45 PM
Brian Fuerbach   Ok so, two thoughts: 1.) set your decel valve to...   Mar 28 2022, 10:34 PM
Van B   Ok, I’m too tired to think straight but yes, you...   Mar 28 2022, 12:29 AM
wonkipop   Ok, I’m too tired to think straight but yes, yo...   Mar 28 2022, 01:34 AM
emerygt350   But here he is running a 123 right? so you have to...   Mar 28 2022, 08:43 AM
Van B   Definitely possible. As you've seen through my...   Mar 28 2022, 09:13 AM
Van B   Definitely possible. As you've seen through m...   Mar 28 2022, 09:17 AM
emerygt350   Definitely possible. As you've seen through ...   Mar 28 2022, 09:24 AM
Van B   AFM is literally the barn door. it attaches to the...   Mar 28 2022, 09:36 AM
emerygt350   AFM is literally the barn door. it attaches to th...   Mar 28 2022, 10:38 AM
Van B   AFM is literally the barn door. it attaches to t...   Mar 28 2022, 10:43 AM
wonkipop   AFM is literally the barn door. it attaches to th...   Mar 28 2022, 03:00 PM
ClayPerrine   The AFM in an L-Jet system will push fuel into the...   Mar 28 2022, 09:48 AM
emerygt350   So a decel hooked to the boot would be unmeasured ...   Mar 28 2022, 10:37 AM
Van B   So a decel hooked to the boot would be unmeasured...   Mar 28 2022, 10:42 AM
wonkipop   So a decel hooked to the boot would be unmeasured...   Mar 28 2022, 03:41 PM
emerygt350   Is this correct? I know they changed stuff every...   Mar 28 2022, 10:44 AM
emerygt350   If it is, man that doesn't make much sense to ...   Mar 28 2022, 10:47 AM
Van B   If it is, man that doesn't make much sense to...   Mar 28 2022, 10:56 AM
emerygt350   Too much advance could certainly do it, but there ...   Mar 28 2022, 11:02 AM
Van B   the little subset square on the airbox is meant to...   Mar 28 2022, 10:45 AM
Brian Fuerbach   Regardless of the vac adv or retard, the centrifug...   Mar 28 2022, 01:43 PM
Van B   Regardless of the vac adv or retard, the centrifu...   Mar 28 2022, 05:16 PM
emerygt350   Yeah,we were only speculating on 'way too much...   Mar 28 2022, 02:04 PM
r_towle   My experience with this is two things. 1) a dirty ...   Mar 28 2022, 03:06 PM
emerygt350   But wonkipop, that completely ignores the ecus res...   Mar 28 2022, 03:52 PM
wonkipop   But wonkipop, that completely ignores the ecus re...   Mar 28 2022, 03:56 PM
emerygt350   I would bet it does, otherwise they would have jus...   Mar 28 2022, 04:20 PM
wonkipop   I would bet it does, otherwise they would have ju...   Mar 28 2022, 04:59 PM
emerygt350   It would be interesting to know what the dizzy con...   Mar 28 2022, 05:09 PM
wonkipop   It would be interesting to know what the dizzy co...   Mar 28 2022, 05:53 PM
wonkipop   ps i was trying to look for info on the fpr in th...   Mar 28 2022, 06:40 PM
wonkipop   @Emerygt350 . always have to go back and re-read ...   Mar 28 2022, 08:11 PM
Van B   Your vac readings are what my decel valve yielded ...   Mar 28 2022, 10:55 PM
wonkipop   Your vac readings are what my decel valve yielded...   Mar 29 2022, 12:51 AM
wonkipop   i'll translate the above rambling thought. be...   Mar 29 2022, 01:08 AM
wonkipop   i did a bit more reading. because i was intereste...   Mar 29 2022, 07:25 AM
emerygt350   That makes good sense.   Mar 29 2022, 08:59 AM
Brian Fuerbach   Appreciate all the replys. Took me a bit to read t...   Mar 29 2022, 02:37 PM
wonkipop   Appreciate all the replys. Took me a bit to read ...   Mar 29 2022, 03:02 PM
Brian Fuerbach   Appreciate all the replys. Took me a bit to read...   Mar 29 2022, 04:10 PM
wonkipop   try measuring the Air Fuel Mix at idle too to comp...   Mar 29 2022, 04:45 PM
wonkipop   @Brian Fuerbach that description above about L je...   Mar 29 2022, 05:04 PM
Brian Fuerbach   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 29 2022, 07:36 PM
wonkipop   that is correct brian   Mar 29 2022, 08:26 PM
wonkipop   i am doing some more reading on just how the L jet...   Mar 29 2022, 08:38 PM
Brian Fuerbach   by looking for info on your afr condition i now...   Mar 30 2022, 09:36 AM
wonkipop   by looking for info on your afr condition i no...   Mar 30 2022, 04:09 PM
Brian Fuerbach   [quote name='Brian Fuerbach' post='2991765' date=...   Mar 30 2022, 05:20 PM
emerygt350   The fouling is something to think about though. I...   Mar 30 2022, 05:03 AM
wonkipop   The fowling is something to think about though. ...   Mar 30 2022, 06:39 AM
emerygt350   The fowling is something to think about though. ...   Mar 30 2022, 06:47 AM
wonkipop   [quote name='wonkipop' post='2991722' date='Mar 3...   Mar 30 2022, 04:16 PM
Brian Fuerbach   [quote name='wonkipop' post='2991722' date='Mar ...   Mar 30 2022, 05:10 PM
emerygt350   [quote name='wonkipop' post='2991854' date='Mar 3...   Mar 30 2022, 05:30 PM
emerygt350   Let's just blame autocorrect on all of that......   Mar 30 2022, 05:26 PM
wonkipop   Let's just blame autocorrect on all of that.....   Mar 30 2022, 05:59 PM
wonkipop   chookyard = chickenyard. think the limeys call th...   Mar 30 2022, 05:39 PM
Van B   chookyard = chickenyard. think the limeys call t...   Mar 30 2022, 08:26 PM
wonkipop   chookyard = chickenyard. think the limeys call ...   Mar 30 2022, 09:38 PM
wonkipop   here is another note on that decel thing. the ide...   Mar 30 2022, 06:16 PM
emerygt350   I bet Mr. Injector could tell us exactly how they ...   Mar 30 2022, 06:17 PM
wonkipop   I bet Mr. Injector could tell us exactly how they...   Mar 30 2022, 06:34 PM
Brian Fuerbach   I checked the fuel press reg and all is golden. :...   Mar 30 2022, 08:40 PM
wonkipop   I checked the fuel press reg and all is golden. ...   Mar 30 2022, 09:06 PM
Brian Fuerbach   I checked the fuel press reg and all is golden. ...   Mar 31 2022, 02:02 PM
wonkipop   [quote name='wonkipop' post='2991943' date='Mar 3...   Mar 31 2022, 03:30 PM
wonkipop   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Mar 31 2022, 04:30 PM
emerygt350   Does that line head into the plenum or the air box...   Mar 31 2022, 05:41 PM
Brian Fuerbach   Wonkipop, I did read the thread on on the cap. I ...   Mar 31 2022, 08:08 PM
wonkipop   Wonkipop, I did read the thread on on the cap. I...   Mar 31 2022, 09:23 PM
emerygt350   interesting. I assume that PCV system is like the...   Apr 1 2022, 06:42 AM
Brian Fuerbach   interesting. I assume that PCV system is like th...   Apr 1 2022, 01:26 PM
wonkipop   interesting. I assume that PCV system is like th...   Apr 1 2022, 04:33 PM
Brian Fuerbach   interesting. I assume that PCV system is like t...   Apr 1 2022, 05:17 PM
wonkipop   [quote name='wonkipop' post='2992472' date='Apr 1...   Apr 1 2022, 06:11 PM
emerygt350   No, no fuel cut on the djet, but I found the rich ...   Apr 1 2022, 06:15 PM
wonkipop   No, no fuel cut on the djet, but I found the rich...   Apr 1 2022, 06:21 PM
wonkipop   No, no fuel cut on the djet, but I found the rich...   Apr 1 2022, 06:42 PM
Van B   You guys just aren’t willing to talk about spark...   Apr 1 2022, 06:39 PM
wonkipop   You guys just aren’t willing to talk about spar...   Apr 1 2022, 06:47 PM
Brian Fuerbach   You guys just aren’t willing to talk about spa...   Apr 1 2022, 07:25 PM
wonkipop   [quote name='wonkipop' post='2992522' date='Apr 1...   Apr 1 2022, 07:38 PM
Van B   Distributor vacuum is read/pulled from the throttl...   Apr 1 2022, 07:05 PM
wonkipop   Distributor vacuum is read/pulled from the thrott...   Apr 1 2022, 07:24 PM
Van B   Distributor vacuum is read/pulled from the throt...   Apr 1 2022, 07:32 PM
wonkipop   [quote name='wonkipop' post='2992530' date='Apr 1...   Apr 1 2022, 07:44 PM
Van B   ok. so i have the distributor bit right. phew...   Apr 1 2022, 07:44 PM
wonkipop   ok. so i have the distributor bit right. phew...   Apr 1 2022, 07:47 PM
Van B   Right now I have a relay board baking in the oven ...   Apr 1 2022, 07:07 PM
wonkipop   Right now I have a relay board baking in the oven...   Apr 1 2022, 07:51 PM
wonkipop   that chart was great. just as a translation device...   Apr 1 2022, 08:16 PM
Brian Fuerbach   that chart was great. just as a translation devic...   Apr 2 2022, 02:42 PM
Van B   Yes. AFR is the bottom scale. There are various g...   Apr 2 2022, 03:45 PM
wonkipop   @Brian Fuerbach although that specific chart has...   Apr 2 2022, 06:19 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 06:26 AM
