FS Misc 914 parts, gauges, wilwood brakes, 914 rear caliper etc just ask |
d914 |
Mar 30 2022, 05:56 PM
Silverdot gauge set.. could use some TLC, been in storage $125
regular gauge set $100 sold VDO clock $45 sold Temp 35 volt 35 silver dot 6 tach sold newer VDO temp and volt $25 each switches, I believe Porsche emergency flasher and lights.. $20 each rear 914 calipers w e brake $200/set sold Hella fogs. $25 to good home. Need seals and blubs sold Ignition switch w key. $25 sold If out of line tell me.. if you need anything just ask. Id rather sell than sit on.. so just ask. |
d914 |
Mar 30 2022, 05:59 PM
d914 |
Mar 30 2022, 06:01 PM
d914 |
Mar 30 2022, 06:02 PM
d914 |
Mar 30 2022, 06:03 PM
d914 |
Mar 30 2022, 06:05 PM
5.25 bolt spacing, you will need new bracket.. No PADS.. hey were for another set of bakes. https://www.wilwood.com/PDF/Flyers/fl104.pdf sold |
76-914 |
Mar 30 2022, 07:20 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'll take the black dot (not silver dot) gages and the clock, pls
d914 |
Mar 30 2022, 07:35 PM
mgphoto |
Mar 30 2022, 10:42 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Interested in the Wilwoods, don’t see a price
d914 |
Mar 31 2022, 03:12 AM
Wilwoods list for $150 each call it $200 and I’ll look around for the pads. I know where they are just have to make sure they are the right ones.
d914 |
Mar 31 2022, 06:42 AM
Superhawk996 |
Mar 31 2022, 07:01 AM
914 Guru Group: Members Posts: 5,819 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I'll take the tach
Shivers |
Mar 31 2022, 08:19 AM
Senior Member Group: Members Posts: 2,373 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
The Wilwoods, can you tell me what mounting spacing they have. I have some "M's" off of a T for the back, compared to the superlites I have for the front, they weigh a ton. Thanks
d914 |
Mar 31 2022, 08:29 AM
they look to be 5.25.. Buddy used on his and welded on new brackets. and also very light.
NO PADS.. they were for another set of brakes.. |
d914 |
Mar 31 2022, 09:13 AM
Ignition switch w key. $25 Plus shipping |
sjhenry1075 |
Mar 31 2022, 09:35 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Silverdot gauge set.. could use some TLC, been in storage $125 regular gauge set $100 sold VDO clock $45 sold Temp 35 volt 35 silver dot 6 tach sold newer VDO temp and volt $25 each switches, I believe Porsche emergency flasher and lights.. $20 each rear 914 calipers w e brake $200/set sold Hella fogs. $25 to good home. Need seals and blubs Ignition switch w key. $25 If out of line tell me.. if you need anything just ask. Id rather sell than sit on.. so just ask. Do you have a pic of the fog lights? |
d914 |
Mar 31 2022, 09:46 AM
Silverdot gauge set.. could use some TLC, been in storage $125 regular gauge set $100 sold VDO clock $45 sold Temp 35 volt 35 silver dot 6 tach sold newer VDO temp and volt $25 each switches, I believe Porsche emergency flasher and lights.. $20 each rear 914 calipers w e brake $200/set sold Hella fogs. $25 to good home. Need seals and blubs Ignition switch w key. $25 If out of line tell me.. if you need anything just ask. Id rather sell than sit on.. so just ask. Do you have a pic of the fog lights? working on it.. got rejected on size.. work just got in the way!!! |
d914 |
Mar 31 2022, 09:50 AM
sjhenry1075 |
Silverdot gauge set.. could use some TLC, been in storage $125 regular gauge set $100 sold VDO clock $45 sold Temp 35 volt 35 silver dot 6 tach sold newer VDO temp and volt $25 each switches, I believe Porsche emergency flasher and lights.. $20 each rear 914 calipers w e brake $200/set sold Hella fogs. $25 to good home. Need seals and blubs Ignition switch w key. $25 If out of line tell me.. if you need anything just ask. Id rather sell than sit on.. so just ask. Do you have a pic of the fog lights? working on it.. got rejected on size.. work just got in the way!!! no problem, if it's easier I'll message my email |
sjhenry1075 |
Mar 31 2022, 09:51 AM
Lo-Fi Version | Time is now: 15th May 2024 - 12:11 PM |
