A few things to know before stealing my 914 |
MCShack |
Apr 4 2022, 05:12 PM
Member Group: Members Posts: 70 Joined: 7-March 21 From: Ohio, USA Member No.: 25,305 Region Association: Upper MidWest |
Anyone see this story on Hagerty the other day? I found it slightly clever and somewhat humorous. Please delete if this has already been posted or is not appropriate for any reason. (IMG:style_emoticons/default/confused24.gif)
A few things to know before stealing my 914: https://www.hagerty.com/media/advice/a-few-...u-steal-my-914/ |
Spoke |
Apr 4 2022, 05:24 PM
That is pretty good.
Apr 4 2022, 05:48 PM
All I kept thinking is that a valid response is a check list of vendor-members that can help with each item listed as broken…..lol
ClayPerrine |
Apr 4 2022, 06:43 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
rjames |
Apr 4 2022, 07:44 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif)
ClayPerrine |
Apr 5 2022, 03:07 AM
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) If you must have the look of carbs, then use this: https://store.jenvey.co.uk/heritage-idf-tbo...-quad-tdfq45-48 They even make them to replace the IDA3C. Clay |
MCShack |
Apr 5 2022, 09:45 AM
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) If you must have the look of carbs, then use this: https://store.jenvey.co.uk/heritage-idf-tbo...-quad-tdfq45-48 They even make them to replace the IDA3C. Clay Those look sweet, but how do they sound? While I prefer a D-Jet or an L-Jet fuel injection system, I gotta admit that I love the sound of the Italian dual Weber carbs or even the twin Dell'Ortos on a well-tuned 914/4. Of course carbs are the only way to go with a flat-six, but flat-fours were made for fuel injection. |
rjames |
Apr 5 2022, 10:00 AM
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) Clay Agreed- was being sarcastic. (IMG:style_emoticons/default/shades.gif) |
ClayPerrine |
Apr 5 2022, 10:42 AM
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) Clay Agreed- was being sarcastic. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/chair.gif) |
Apr 5 2022, 05:47 PM
Dual carbs FTW
ClayPerrine |
Apr 6 2022, 11:05 AM
DRPHIL914 |
Apr 6 2022, 12:36 PM
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) If you must have the look of carbs, then use this: https://store.jenvey.co.uk/heritage-idf-tbo...-quad-tdfq45-48 They even make them to replace the IDA3C. Clay @ClayPerrine ive not seen these before, but seems like they would work nice with right manifolds on a 2.1/2056 type IV motor, what EM system and ECU would you then use?, and linkage? a Tangerine carb linkage system? (IMG:style_emoticons/default/idea.gif) |
ClayPerrine |
Apr 6 2022, 01:00 PM
Finally a legit reason to remove the FI and install carbs. (IMG:style_emoticons/default/happy11.gif) There is NEVER a legit or even a close to good reason to remove fuel injection and install carbs. (IMG:style_emoticons/default/poke.gif) If you must have the look of carbs, then use this: https://store.jenvey.co.uk/heritage-idf-tbo...-quad-tdfq45-48 They even make them to replace the IDA3C. Clay @ClayPerrine ive not seen these before, but seems like they would work nice with right manifolds on a 2.1/2056 type IV motor, what EM system and ECU would you then use?, and linkage? a Tangerine carb linkage system? (IMG:style_emoticons/default/idea.gif) If it were me, I would use a Tangerine throttle linkage kit, and Microsquirt. If you already have carbs, you just need the throttle bodies. Clay |
Lo-Fi Version | Time is now: 17th May 2024 - 06:19 PM |
