How to fix blinker?, ??? |
BK911 |
Apr 10 2022, 05:38 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
Pass rear blinker no workie.
No continuity from fuse 6 to red/Grey wire at rear light box. Am I reading the wire diagram correctly? If so, how to fix? Thinking of pulling a new wire using scotch locks near the fuse and in the trunk. Whatcha think? |
914Mels |
Apr 11 2022, 11:04 AM
Member Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California |
Rarely will it be the actual wire that is causing the problem. You need to check connections for corrosion or bad connections. On a fifty year old car that is the weak link to start with. Scotch locks are a poor wire repair, yes they will work but not a very good connection.
friethmiller |
Apr 11 2022, 12:28 PM
Member Group: Members Posts: 476 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
904svo |
Apr 11 2022, 02:36 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
WAG, do you have the correct bulb installed?
Puebloswatcop |
Apr 11 2022, 05:25 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
When I look at the Diagram fuse 6 is for the parking lights, fuse 9 is for the stop, turn and back up lights. Assuming you are working on a 1972.
bkrantz |
Apr 11 2022, 07:04 PM
914 Guru Group: Members Posts: 7,766 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
This
StarBear |
Apr 12 2022, 07:41 AM
Senior Member Group: Members Posts: 1,885 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
BK911 |
Apr 12 2022, 08:42 AM
Rarely will it be the actual wire that is causing the problem. You need to check connections for corrosion or bad connections. On a fifty year old car that is the weak link to start with. Scotch locks are a poor wire repair, yes they will work but not a very good connection. All connections are surgically clean. Had a mouse nest in the tunnel so thunk maybe a critter chewed through a wire. |
BK911 |
Apr 12 2022, 08:43 AM
BK911 |
Apr 12 2022, 08:55 AM
When I look at the Diagram fuse 6 is for the parking lights, fuse 9 is for the stop, turn and back up lights. Assuming you are working on a 1972. That might explain why I cannot figure this out! Fuse 6 said it want to "clearance lamps" No idea what that is, but somewhere else I saw "clearance lamps / blinkers" |
BK911 |
Apr 12 2022, 06:08 PM
When I look at the Diagram fuse 6 is for the parking lights, fuse 9 is for the stop, turn and back up lights. Assuming you are working on a 1972. Yup you are right. My RR parking light doesn't either! So LR, LF and RF work. Going to pull the Hazzard switch and check continuity. |
Apr 12 2022, 08:01 PM
The most appropriate use for Scotch Locks is holding down the bottom of your garbage can. They cause more problems than they fix. If you ever find yourself attempting to use one, just hit your hand with a hammer and shout "NOOO!" at the top of your lungs.
--DD (Why, yes, I don't like them. Why do you ask? (IMG:style_emoticons/default/wink.gif) ) |
fixer34 |
Apr 13 2022, 04:17 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Lo-Fi Version | Time is now: 18th May 2024 - 12:38 AM |
