021.101.109 or 021.101.109.A, Flywheel Inspection Plug/Torque Converter Plug |
Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
L-Jet914 |
Apr 14 2022, 02:51 PM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
This is part number 36 Main Group 1 in the PET. NLA as far as I've found. This part resides in the rear of then engine case and provided access to the torque converter bolts on the SportMatic transmissions, and called a timing mark stopper for the regular manual transmissions.
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 8th May 2024 - 04:24 PM |
