Sheared off bolt head, Front axle |
Van B |
May 4 2022, 07:52 AM
Senior Member Group: Members Posts: 1,613 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
My plan is to get a nut and turn down one end so that it fits inside the crossmember clearance hole, then MIG weld inside the nut. Good Plan! (IMG:style_emoticons/default/smilie_pokal.gif) That cross member will swing out enough to get a nut in there. take the other bolt off and you'll see what I mean. |
PatMc |
May 4 2022, 10:15 AM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
Smack the bolt with a hammer a few times in an attempt to break the rust bond of the threads...a bit of penetrating oil wouldn't hurt. Then bend the strap/bracket a bit with a prybar to get it off the bolt threads so you can grab it TIGHT with a pair of vise grips...
That bolt likely broke under tension...overtightened or ??. There is no thread tension remaining, so it should come out nicely. DO NOT use an EZ out. I'm always amazed at folks who believe and EZ out, which is smaller and more brittle (harder) than the bolt that broke, will get out a broken bolt. EZ outs belong in the garbage. |
rhodyguy |
May 4 2022, 10:18 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,098 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Don't break the other bolt when experimenting.
Eric_Shea |
May 4 2022, 10:43 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'd just remove the cross bar fasteners, drop it dow a bit and you should have enough thread there to heat and simply put a good Vise-Grip on.
rgalla9146 |
May 4 2022, 01:27 PM
Advanced Member Group: Members Posts: 4,570 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
You may not want to remove the crossmember but your best shot is with all interference removed. Drill a 1/4" hole in the stamped metal mount above the stuck bolt and flood the interior of the mount with your favorite penetrant. I think that can be done without romoving thr tank. Vise grips allow back-and-forth motion....pipe wrenches don't. |
Lo-Fi Version | Time is now: 16th June 2024 - 03:14 PM |
