> Thermostat Question, How does it work?
pbanders
post May 4 2022, 09:16 AM
While I may have done a transistor-by-transistor analysis of the ECU and used pSpice to simulate the injector driver circuit, I've never done squat with my thermostat system. Basically, it works, so I leave it alone.
But I'm curious, how do the bellows work? When the car is hot, the bellows expand, and the cable tension is released. Is there an internal spring? Something about wax? Help me out here, thanks.
mrholland2
post May 4 2022, 09:17 AM
QUOTE(pbanders @ May 4 2022, 08:16 AM) *
I think there is a spring on the flap shaft that pulls against the thermostat.
Mark Henry
post May 4 2022, 09:35 AM
that's what I do!
QUOTE(mrholland2 @ May 4 2022, 11:17 AM) *
Close, the spring on the flaps opens the flaps and provides tension for the cable, as the bellows expands/contracts it lets the flaps move.
If your T-stat bellows is always expanded then she be fuched.
914werke
post May 4 2022, 10:08 AM
Brad are you are asking what is contained inside the unit that causes the bellows expansion?
I believe it is a wax that liquefies when up to temp?
post May 4 2022, 10:21 AM
914-6 GT in waiting
Always test it inside the bracket or it will over expand.
emerygt350
post May 4 2022, 11:42 AM
I ripped my old one apart pulling it out of the car, I think it is a bimetal design perhaps? There was no 'wax' inside the bellows. Or perhaps I let all the magic smoke out when I ripped it open with my pliers.... Seemed more like a metal expansion contraction type device. Not a spring inside though, unless it is contained within the bellow portion. I think. I was kind of pissed at it for how stuck it was.
pbanders
post May 4 2022, 12:43 PM
Here's a 914 thermostat in operation:
https://www.youtube.com/watch?v=WFrcKSB-oUM
From what I can tell, it's a metal bellows filled with wax, which expands when heated and contracts when cooled. Old tech, but it works.
barefoot
post May 4 2022, 01:19 PM
This may help:
iankarr
post May 4 2022, 02:00 PM
I believe there’s a liquid (alcohol?) sealed inside the bellows and heat causes it to turn into a vapor and expand…
pbanders
post May 19 2022, 11:08 AM
Ian Karr is correct, the working fluid is alcohol. Richard Atwell has an excellent page on the details of the thermostat, with all the info you'll ever need.
https://ratwell.com/technical/Thermostats.html
Oh, and I received my new thermostat from Awesome Powdercoat, a very nicely made component. As my existing thermostat seems to be working fine, this new one will go into my spares cabinet - which is getting fuller all the time.
- Lo-Fi Version Time is now: 3rd July 2025 - 06:57 AM
