| Mendivil26 |
May 10 2022, 02:25 PM
Newbie ![]() Group: Members Posts: 31 Joined: 26-July 18 From: Riverside, Ca. Member No.: 22,344 Region Association: Southern California |
Story time:
Last time I parked my '75 2.0 to restore the front suspension, it was running relatively fine. As usual, a simple task estimated to take a few weeks turned into months, due to lack of time & budget. A few months go by and I notice the interior is flooded in gas, thankfully the car had no carpets and nothing caught fire. I did my research and diagnosed the leak came from the plastic fuel lines that go through the tunnel; simple enough, I'll replace them with SS lines. I go ahead and clear the interior of any remaining fuel; drain the rest of the gas tank, only to notice the horrible condition it's in; chunks of rust coming out of it. Now I not only have to replace the fuel lines but I also have to either restore the tank or replace it (dansk tank $230 plus SS line $170). My goal with this car is to turn it into a baja inspired 914; and since I don't really care about "originality", I wondered: what if I replaced it with a universal fuel tank used by dune buggies/prerunners (Jaz, RCI, etc) and placed it in the rear trunk? They seem to be easy to find secondhand and not so expensive. I started looking into it and noticed obviously 914 racecars have "fuel cells" but they all kept them in the front. This is a list of pros & cons I came up with, and since it hasn't been done before I assume that it'll be a very unpopular inion, so please go ahead and talk me out of it since I'm biased and can only think of reasons to actually do it. Pros: No fuel lines running through tunnel = simpler system & shorter lines. Less or just as expensive for a unique or "custom" look, since I've never seen it done before. Shifts weight to the rear, which is better for my application Cons: Safety? Rear suspension is being reinforced so the tank could be protected by the cage I'll build around it in case of a rear end accident, but the fact that it's closer to the engine and hot temperatures might be a bigger issue. Anything else I might not be considering? Has someone seen it done before? If so, please share pictures/info. Picture of how it sits right now with UTV tires, for reference: Picture of what I'm thinking of maybe doing: ![]() |
Mendivil26 Fuel tank relocation to rear? May 10 2022, 02:25 PM
ClayPerrine That is an absolutely terrible idea. The rear tru... May 10 2022, 03:08 PM
ValcoOscar
That is an absolutely terrible idea. The rear tr... May 10 2022, 03:11 PM
ClayPerrine
That is an absolutely terrible idea. The rear t... May 11 2022, 10:28 AM
Van B
That is an absolutely terrible idea. The rear tr... May 11 2022, 10:46 AM
emerygt350 That trunk gets super warm. I would do the front ... May 10 2022, 03:21 PM
930cabman Think Ford Pinto, rear end collision
BTW: she loo... May 10 2022, 03:26 PM
Craigers17 I would leave in up front as well, but since you a... May 10 2022, 04:14 PM
rhodyguy With the fuel storage in the stock location, less ... May 10 2022, 04:43 PM
BillJ Sticking it in the rear is bad. May 10 2022, 04:49 PM
Krieger
:agree: :rot... May 12 2022, 10:55 PM
Front yard mechanic open up the hood and put a aluminum cylinder tank ... May 10 2022, 05:02 PM
jrmdir
open up the hood and put a aluminum cylinder tank... May 20 2022, 01:49 PM
Front yard mechanic
[quote name='Front yard mechanic' post='3000947' ... Jun 3 2022, 02:09 PM
PCH Also, if you put the tank in the back, you won... May 10 2022, 05:55 PM
Bullethead Baja 914's are cool, but proper weight distrib... May 10 2022, 06:12 PM
Lockwodo Clay, I have to wonder about the bag of kitty litt... May 11 2022, 10:36 AM
ClayPerrine
Clay, I have to wonder about the bag of kitty lit... May 11 2022, 11:08 AM
Spoke Compared to Clay's crash, mine was a minor den... May 11 2022, 11:05 AM
Picture of how it sits right now with UTV tires, ... May 11 2022, 11:18 AM
Dave_Darling
I've been thinking about going the Baja route... May 12 2022, 06:31 PM
I've been thinking about going the Baja rout... May 12 2022, 09:57 PM
Dave_Darling
Sure, but once i move there i'll have another... May 13 2022, 10:48 AM
Shivers I understand wanting to keep the front end light f... May 11 2022, 11:39 AM
Mendivil26 Thank you all for the great responses!
I under... May 12 2022, 10:59 AM
sixnotfour :beer2: May 12 2022, 11:22 PM
mlindner Not what your looking for but just a different loo... May 13 2022, 04:00 AM
Mendivil26
Not what your looking for but just a different lo... May 20 2022, 09:32 AM
Not what your looking for but just a different l... May 20 2022, 09:36 AM
SirAndy Reproduction 356 fuel tank. $400-500.
It doe... May 20 2022, 09:55 AM
930cabman
It do... May 20 2022, 01:06 PM
mlindner Yes it is a 356 tank, it was going to be a fuel ce... May 20 2022, 11:45 AM
mlindner SirAndy I do understand where you are coming from,... May 20 2022, 02:08 PM
Mendivil26 Thanks to everyone for your great advise.
I found ... Jun 3 2022, 12:33 PM
914 Ranch I'm sorry I can't give you a link, but the... Jun 3 2022, 05:07 PM
bkrantz Not to rain on any parades, but the frunk also ser... Jun 3 2022, 08:29 PM
Mikey914 Factory put the tank where they did for a reason. ... Jun 4 2022, 02:30 AM
mlindner I get the crumple zones BUT all the early 911 had ... Jun 4 2022, 06:52 AM
bkrantz
I get the crumple zones BUT all the early 911 had... Jun 4 2022, 11:25 AM
Dave_Darling If you'll look carefully, you might notice tha... Jun 5 2022, 03:07 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:09 AM |
