FS: Porsche factory 1977 short length 930 transmission SOLD Thank you, Set up for 914- LDS, oil cooling, special PMB special trailing arms |
burton73 |
May 15 2022, 06:02 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
With LDS, oil cooling, special PMB special trailing arms $9,000. OBO I have a fresh fully rebuilt By GBox https://www.gboxweb.com/index.html done for Army Dudes V8 car many years ago just never run. Flipped ring and set up with oiling and external oil pump fresh except that it has been setting in my temp controlled west coast shop for 10 years. GBox said you would not need to add the oil cooling but it is all there. Set up with hydraulic clutch. Bracket from 930 Turbo. I have KEP adapter for SBC and clutch and throw-out bearing. This transmission will handle over 700 Horse Power This would work great for a V8 conversion but for all of you that know me, more is better, bigger is better and this will handle all the power that you can put to it. 930 Turbo 1977 4-speed fully-synchronized transaxle Manufactured by Porsche (ZF) Short bell housing Plate-type limited-slip differential Rod shift Single-plate clutch Gear ratios: 1st gear: 2.25 2nd gear: 1.304 3rd gear: 0.893 4th gear: 0.656 Ring and pinion: 4.22 I also have the fresh trailing arms with Elephant Polly bronzes reinforced by PMB with their tube reinforcement and early 911 parking brake, 930 fresh stub axles, bearings and fresh brand new 930 CV joints from PMB. Plus, I will through in a par of rebuilt Boxster rear calipers and adapters from Rick Johnston Speedo drive with and a 911 Speedo. You just need some custom Swing away Axles and Cable Shifter set up. If you have the vision this will handle the HP and engine torque and not blow up. Bob B [attachmentid=836 100] |
burton73 |
Jun 13 2022, 01:47 PM
Bump for the people that need the massive horsepower and torque trans that can take all that you can put to it. $9,000 OBO
Bob B (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) (IMG:style_emoticons/default/driving-girl.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 11:39 PM |
