> Targa pad removal…, Big thanks to 914Toy aka Keith Hully ! It’s done….
jim_hoyland
post May 16 2022, 02:12 PM
Get that VIN ?
Got a pair of new latches for the targa top. Seven horizontal screws and 5 vertical from underneath. Screw heads are buried into the pad. Any tricks here ?I found maybe three of the screws.
jim_hoyland   Targa pad removal…   May 16 2022, 02:12 PM
Root_Werks   On the pad I removed (and tossed), the foam inside...   May 16 2022, 02:34 PM
jim_hoyland   On the pad I removed (and tossed), the foam insid...   May 16 2022, 03:06 PM
JamesM   The screw heads don't always match straight t...   May 18 2022, 01:23 PM
Root_Werks   I would take the two side panels off, makes things...   May 16 2022, 03:50 PM
jim_hoyland   I would take the two side panels off, makes thing...   May 16 2022, 03:53 PM
windforfun   The AA roll bar pad fits almost perfectly. And ho...   May 16 2022, 06:57 PM
jim_hoyland   The AA roll bar pad fits almost perfectly. And h...   May 16 2022, 07:39 PM
Front yard mechanic   Use a long number one screwdriver . The length hel...   May 16 2022, 07:13 PM
76-914   Jim, the correct size Phillips is #1 on the list. ...   May 16 2022, 07:17 PM
jim_hoyland   Got the #1 long shaft screwdriver. Had to stop aft...   May 16 2022, 07:41 PM
windforfun   Got the #1 long shaft screwdriver. Had to stop af...   May 16 2022, 07:53 PM
windforfun   BTW, some of the screws may already be missing. M...   May 17 2022, 04:11 PM
jim_hoyland   This project is on hold for awhile. Will restart w...   May 17 2022, 06:00 PM
bob164   Jim, When you get back to it, give me a call and I...   May 18 2022, 06:33 PM
jim_hoyland   Jim, When you get back to it, give me a call and ...   May 18 2022, 06:51 PM
Dave_Darling   I think I recall that the two little tiny screws i...   May 18 2022, 11:16 PM
windforfun   I think I recall that the two little tiny screws ...   May 19 2022, 10:12 AM
mepstein   I hate those tiny screws. Made worse after 50 year...   May 19 2022, 08:38 AM
jim_hoyland   Restarting the targa pad removal. Gonna pull the p...   Aug 16 2022, 04:18 PM
JeffBowlsby   I use an awl as a probe to locate the screw heads.   Aug 16 2022, 04:50 PM
jim_hoyland   I use an awl as a probe to locate the screw heads...   Aug 16 2022, 07:05 PM
914_teener   I'll be in Long Beach this coming Sat Jim if y...   Aug 16 2022, 07:25 PM
jim_hoyland   I'll be in Long Beach this coming Sat Jim if ...   Aug 16 2022, 08:52 PM
jim_hoyland   After hours of frustration, I trekked down to Keit...   Aug 18 2022, 04:28 PM
- Lo-Fi Version Time is now: 6th July 2025 - 01:33 AM
