Targa pad removal…, Big thanks to 914Toy aka Keith Hully ! It’s done…. |
jim_hoyland |
May 16 2022, 02:12 PM
Get that VIN ? Group: Members Posts: 9,269 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Got a pair of new latches for the targa top. Seven horizontal screws and 5 vertical from underneath. Screw heads are buried into the pad. Any tricks here ?I found maybe three of the screws.
Attached thumbnail(s) Attached image(s) |
Root_Werks |
May 16 2022, 02:34 PM
Village Idiot Group: Members Posts: 8,308 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
On the pad I removed (and tossed), the foam inside the little holes had been shredded up enough to block the screw heads. I used a little pick to sort of clean out each hole. The screw heads don't always match straight to the hole in the pad either. It's frustrating and slow. You should be able to see each screw head....should.
jim_hoyland |
May 16 2022, 03:06 PM
On the pad I removed (and tossed), the foam inside the little holes had been shredded up enough to block the screw heads. I used a little pick to sort of clean out each hole. The screw heads don't always match straight to the hole in the pad either. It's frustrating and slow. You should be able to see each screw head....should. Good suggestion ! Do the panel covering the rear pillars have to come off ? I can see one screw hear may have a mated head, that is the screwdriver can bite in… |
Lo-Fi Version | Time is now: 1st May 2024 - 07:48 PM |
