| JeffBowlsby |
Aug 16 2022, 04:50 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,349 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
I use an awl as a probe to locate the screw heads.
| jim_hoyland |
Aug 16 2022, 07:05 PM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,129 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
| 914_teener |
Aug 16 2022, 07:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I'll be in Long Beach this coming Sat Jim if you need help.
Ping me PM or cell. |
| jim_hoyland |
Aug 16 2022, 08:52 PM
I'll be in Long Beach this coming Sat Jim if you need help. Ping me PM or cell. Thanks Rob. I’ll follow up after taking another run at it (IMG:style_emoticons/default/smile.gif) |
| jim_hoyland |
Aug 18 2022, 04:28 PM
After hours of frustration, I trekked down to Keith’s. He is a master craftsman and endless patience. It took the two of us 3 hours to remove the targa pad; and 10 minutes to replace the targa top latches, that’s why I needed to remove the targa pad.
A couple of observations and suggestions arose: 1. Remove the pillar covers. 2. The pad uses 12 short screws that have a washer under the head. While they hold the pad on securely, they don’t make removal and installation easy. 3. Longer screws will make installation easier; that is, long enough to hold the head while find the holes. 4 The horizontal screws can 1 3/4”, vertical screws around 1 1/2” Longer screws make finding the holes easier. And they helped snug in the ends around the latch cover. And all that was just to replace the two targa top latches….. (IMG:style_emoticons/default/smile.gif) Attached image(s)
Lo-Fi Version | Time is now: 10th September 2026 - 09:50 PM |
