Oil gallery leak under cylinders 3 & 4, Wiggle room with push rod tubes loosened? |
mgphoto |
May 17 2022, 07:48 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello,
I am trying to repair a leak in the oil gallery under cylinders 3-4 As you can nearly see, the air deflection plate is up against the leaking clean out plug. I would like to know from someone who has done this before, can I remove the rocker arms and pull the push rods and tubes as far as they will go, can I move the deflector enough to get access to the plug? Thanks for your help. Mike |
mgphoto |
May 18 2022, 01:19 PM
So pull the engine?
Lo-Fi Version | Time is now: 16th May 2024 - 06:36 PM |
