Tangerine Pushrod Tubes & Seals, Did they work for you? |
pbanders |
May 18 2022, 04:34 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
Looking for feedback on the Tangerine pushrod tubes and seals:
http://www.tangerineracing.com/pushrodtubes.htm Mine leak some, even with new seals, and I don't want to goop up the seals with silicone or whatever to fix it. Anyone else try these? Looking for feedback. My engine is a stock 2.0 L, I assume if I get these I just need the stock length? Thanks. |
Mark Henry |
May 20 2022, 04:06 PM
I've been using Dow55 O-ring grease, but like Jake said the big one is to clean up all the sharp edges so you don't cut the seal.
I also lightly polish the bores with a fine grit flapper wheel. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:27 AM |
