Carb advice |
Carb advice |
yellownerd |
May 19 2022, 12:51 AM
Newbie Group: Members Posts: 3 Joined: 18-May 22 From: USA Member No.: 26,562 Region Association: Upper MidWest |
Thanks in advance for your expert advice!
I’m current running a single ill performing Weber 32/36 progressive carb on my 73 1.7. Before I rip and replace it, is there anything else I should be considering? Any thoughts on dual carbs? |
nditiz1 |
May 19 2022, 09:29 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Set of Weber 40s - Aircooled.net has a setup as well and John sets them up and goes through them.
Intakes from CB Performance - actually could just buy the carbs from them too Phenolic spacer gaskets SvDA distro - pertronix one that removes the points too OR 123 ignition distro CSP linkage OR tangerine OR sync link, not sure where to buy this one, but tangerine is similar Vacuum check valve Carb kit should come with air filters Breather box - can be cheap EMPI or home built Your current Fuel Pump should be good for dual carbs |
Lo-Fi Version | Time is now: 20th May 2024 - 01:21 AM |
