Dim slow turn signal |
jmargush |
May 19 2022, 04:58 AM
Member Group: Members Posts: 458 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
My right side turn signal is not as bright as the left side.
When the headlights are on it flashes slower than the left side. Is this likely a ground issue, or could something else be the culprit? |
Spoke |
May 19 2022, 08:11 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Yes, most likely a grounding or clean connection issue. Follow the wires to the turnsignals and make sure that the connections are clean and secure. Headlights have no operational connection to the turnsignals. Make sure the bulb base and fixture sockets are clean.
nditiz1 |
May 19 2022, 08:29 AM
Senior Member Group: Members Posts: 1,184 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
^ this is probably the issue.
I experienced the same thing with mine. I ended up swapping buckets and that corrected the issue. Too much corrosion that I couldn't seem to clean to get a good connection. |
jmargush |
May 19 2022, 11:45 AM
Thanks
I suspect it may be in the bucket as had resoldiered a terminal that broke off and it was kind of iffy. |
Lo-Fi Version | Time is now: 8th May 2024 - 05:22 PM |
