Dim slow turn signal |
jmargush |
May 19 2022, 04:58 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
My right side turn signal is not as bright as the left side.
When the headlights are on it flashes slower than the left side. Is this likely a ground issue, or could something else be the culprit? |
Spoke |
May 19 2022, 08:11 AM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Yes, most likely a grounding or clean connection issue. Follow the wires to the turnsignals and make sure that the connections are clean and secure. Headlights have no operational connection to the turnsignals. Make sure the bulb base and fixture sockets are clean.
Lo-Fi Version | Time is now: 19th May 2024 - 04:50 PM |
