Another trailing arm bushing question, 914rubber ones fine on stock pin? |
nditiz1 |
May 19 2022, 06:31 AM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
So I noticed while removing my left rear shock that my trailing arm likes to move around a lot. That explains the clunk I heard on my test drive.
I was going to purchase the 914rubber kit, but looks like they are oos on the SS pins. Can I just use the rubber bushings with my current pin barring it has not gotten worn out from current bushing failure? OR if I'm going that route should I get the RD ones, just the bushings. I looked at the elephant kit, but I hate paying for extra tools I don't need. Lastly, Move brake caliper and lines off arm. Unbolt drive shaft from trans flange. Remove rotor Unbolt shock. Remove trailing arm bracket and pin. That's it to get it out right? |
iankarr |
May 19 2022, 08:06 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
No need to replace the pivots if they're solid and not rusty. Just change the bushings.
Lo-Fi Version | Time is now: 20th May 2024 - 05:09 AM |
