914Rubber Door Pull kit, Anyone have one that can take a measurement for me? |
Root_Werks |
May 19 2022, 11:12 AM
Village Idiot Group: Members Posts: 8,308 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
This kit:
https://914rubber.com/rs-inner-door-handle-kit Looking to see how far apart the holes are for the grab handle. My 914 I'm using Type 2 Door grab handles which look okay, but 914 Rubber ones look much nicer. Mine are about 6 1/4" mounting hole spacing. Anyone have a set laying around or installed they can measure for me? -Dan |
Root_Werks |
May 19 2022, 11:15 AM
This is what I'm referring to:
Attached image(s) |
Blake914Rubber |
May 19 2022, 11:58 AM
Newbie Group: Members Posts: 16 Joined: 15-April 20 From: Hillsboro, OR Member No.: 24,141 Region Association: Pacific Northwest |
Root_Werks |
May 19 2022, 12:07 PM
Thanks Blake, that's exactly what I was looking for. Scrunching the mounting 1 3/4" would probably make the handle look funny. Guess I could cut that off the 914Rubber handle? The plastic parts cover the material edges anyway?
Hmm, something for me to ponder. Would certainly look nicer/more finished than my pull handles. Thanks again! |
Blake914Rubber |
May 19 2022, 02:26 PM
Thanks Blake, that's exactly what I was looking for. Scrunching the mounting 1 3/4" would probably make the handle look funny. Guess I could cut that off the 914Rubber handle? The plastic parts cover the material edges anyway? Hmm, something for me to ponder. Would certainly look nicer/more finished than my pull handles. Thanks again! The metal is fairly stout and I couldn't bend it by hand, but I didn't want to bend a set from inventory. If you have the right tools you could trim and rebend if that works for your car. Thanks, Blake |
Costa05 |
May 19 2022, 08:30 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Had a different scenario than you do but my handles which I believe are the 914rubber, I anchored one end in a stock door blind nut position then welded a small metal tab on door framework with blind nut to locate the upper to make it work.
Might be an option?? |
Mikey914 |
May 19 2022, 10:29 PM
The rubber man Group: Members Posts: 12,640 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I like that. King of stock, but not.
Root_Werks |
May 20 2022, 09:47 AM
I like that placement as well.
Although I won't be moving my handle at this point. Don't want to poke any more holes in my new 914Rubber door panels. I tried to use one stock speadnut location. Makes me wonder what other combinations would work with the 914Rubber pull handle distance? Probably a few options. I'm going to buy a kit and shorten the handle. I really like the handle cover and end caps. Attached image(s) |
Lo-Fi Version | Time is now: 29th April 2024 - 12:59 PM |
