Mallory distributor orientation |
Geezer914 |
May 20 2022, 11:53 AM
Geezer914 Group: Members Posts: 1,393 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
If I install a Mallory distributor in the stock location, with #1 at 11:00, the clips that hold the distributor cap interfere with the engine tin, making setting timing difficult. Just want to double check myself, if I rotate the distributor drive gear to one or two teeth so it lines up with 9:00 with the engine at top dead center, I can line up the rotor at 9:00 and be at top dead center for #1?
rhodyguy |
May 20 2022, 01:07 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Did you dimple the tin to make room for the distr body? You pretty much have to. It doesn't take much. I just used a piece of 3/4" dowel and a hammer.
cgnj |
May 20 2022, 07:52 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
If I install a Mallory distributor in the stock location, with #1 at 11:00, the clips that hold the distributor cap interfere with the engine tin, making setting timing difficult. Just want to double check myself, if I rotate the distributor drive gear to one or two teeth so it lines up with 9:00 with the engine at top dead center, I can line up the rotor at 9:00 and be at top dead center for #1? I reindexed the drive gear. I have one with vacuum advance and that was the only way it would fit. |
Jack Standz |
May 21 2022, 11:11 AM
Member Group: Members Posts: 272 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None |
If I install a Mallory distributor in the stock location, with #1 at 11:00, the clips that hold the distributor cap interfere with the engine tin, making setting timing difficult. Just want to double check myself, if I rotate the distributor drive gear to one or two teeth so it lines up with 9:00 with the engine at top dead center, I can line up the rotor at 9:00 and be at top dead center for #1? I have both the centrifugal advance version and the vacuum advance version. After I read Jake Raby`s experience with the vacuum advance version that can fail in a way that could destroy your motor, I use the centrifugal advance version only. This one fits better and no tin dimpling needed in my case. Wouldn't it work and be a whole lot easier to just move each spark plug wire on the distributor cap either one position clockwise or counterclockwise? In other words, put the distributor body in a spot where the clips don't interfere with the tin and then adjust what you now call #1 (#2,3 &4) on the cap to where you have enough rotation to adjust the timing? Your way looks like it'll work, but if you keep the distributor drive where it is and rotate the distributor body (will have to pull the distributor out of the hole, turn just the body, and then reinstall) either 90 degrees clockwise or counterclockwise from where your first photo shows, it looks like you'll have enough timing adjustment rotation. |
Geezer914 |
May 21 2022, 11:36 AM
I indexed the distributor las night so the clips are almost parallel to the sheet metal. If you rotate the cap and switch the wires, the opposite clip hits the sheet metal.
Jack Standz |
May 21 2022, 12:24 PM
Jack Standz |
VaccaRabite |
May 23 2022, 06:37 AM
En Garde! Group: Admin Posts: 13,437 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Can you find Mallory dizzys again? They were NLA for years.
And, yes. You have to dimple the tin to make a Mallory work well. Zach |
rfinegan |
May 23 2022, 07:09 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
Mine looks a lot like fig 1...
Attached thumbnail(s) |
Jack Standz |
May 23 2022, 07:46 AM
Can you find Mallory dizzys again? They were NLA for years. And, yes. You have to dimple the tin to make a Mallory work well. Zach Yes, you are correct, they are NLA for a long time. But, you can still find the optical sensor units, springs (i.e. grey, grey), and caps. It's a shame as they work great and can be tuned to your application. Our 1.8 uses a centrifugal distributor without dimpling the tin, YMMV. |
Jake Raby |
May 23 2022, 05:25 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I have 3-4 of the 4554101 Mallory centrifugal advance units left. These were all dyno only units except for one that came from my wife's engine when I swapped it to a Bluetooth 123 unit.
If someone wants one, message me. |
Jack Standz |
May 23 2022, 07:02 PM
Message sent.
Lo-Fi Version | Time is now: 5th May 2024 - 12:58 AM |
