Mallory distributor orientation |
Geezer914 |
May 20 2022, 11:53 AM
Geezer914 Group: Members Posts: 1,426 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
If I install a Mallory distributor in the stock location, with #1 at 11:00, the clips that hold the distributor cap interfere with the engine tin, making setting timing difficult. Just want to double check myself, if I rotate the distributor drive gear to one or two teeth so it lines up with 9:00 with the engine at top dead center, I can line up the rotor at 9:00 and be at top dead center for #1?
Geezer914 |
May 21 2022, 11:36 AM
I indexed the distributor las night so the clips are almost parallel to the sheet metal. If you rotate the cap and switch the wires, the opposite clip hits the sheet metal.
Lo-Fi Version | Time is now: 24th May 2024 - 05:07 AM |
