turn signal switch |
jmargush |
May 20 2022, 03:38 PM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
need to buy a new turn signal switch but have run across a few questions.
I had a spare one but there are some differences form the one that was in the car. the wire connector that goes along the bottom of the column is wider than one that was in the car so it won't slide in. So figured I would buy a new one,. When I look for a new one it looks like it doesn't include the wiper switch. any one have experience with how this works, do you have to dismantle what you took out of the car and fit a new turn signal switch into the assembly or are the pictures on the webpages just not accurate? recommended sources for a switch? not totally trusting of the pictures i see on sites especially when looking for minor differences |
lierofox |
May 20 2022, 08:15 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
The wiper and turn signal switches are two separate assemblies stacked on top of each other using some small metal tubes that pass through both (the holes that the screws pass through for holding it on the steering column), the wiring harnesses guides just lightly clip together. There's also some differences between the early 70-71 and 72-76 assemblies.
Lo-Fi Version | Time is now: 16th May 2024 - 09:45 AM |
