Engine Bay Pics: Post Yours Here, Post yours and comment on what you see in other's pics |
pbanders |
May 23 2022, 07:18 AM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
[quote name='emerygt350' date='May 23 2022, 05:19 AM' post='3003604']
[quote name='emerygt350' date='May 23 2022, 06:05 AM' post='3003602'] [quote name='pbanders' post='3003407' date='May 22 2022, 07:18 AM'] []. Vacuum should be connected to the 5 mm control port (the one with the thread and nut) and to the 9 mm port on the opposite end, and fresh air from the air box should be connected to the 9 mm port on the side. Most diagrams have the connections to the two 9 mm ports reversed. If you connect it that way, the valve cannot work, because there's vacuum on both sides of the internal diaphragm, and it never moves, no matter what the vacuum is in the intake plenum. [/quote] Just to be clear. Vacuum goes to the small port facing the passenger, that is what I have for sure. And vacuum also to the posterior port facing the rear of the car? Wouldn't that create vacuum on both sides? I don't really know what the construction of the valve looks like internally but it just feels like it would... [/quote] Below is a diagram of the internals of the decel valve. As you can see, it's two chambers separated by a flexible diaphragm, and a valve covering the end port. If vacuum is applied to both the control and the side port, and the end port is connected to atmospheric pressure, the diaphragm has the same pressure on both sides and will never move, no matter what pressure is applied. This configuration is the way many of the hose diagrams show. Now, swap the hoses on the side and end port, so that the side port is connected to atmospheric pressure and the end port to vacuum. If P1 is at atmospheric pressure and P2 is at a vacuum below the setpoint, the tension spring will hold the valve shut. Once P2 is at a high enough vacuum to overcome the spring tension, the valve opens, and P1 now cannot exceed the setpoint vacuum, limiting the vacuum - which is why the device is also called a vacuum limiter. BTW, this is not conjecture, I have tested it in both configurations using my hand vacuum pump and hoses and tee connectors to apply vacuum to the ports. You can test it yourself, this is how it works. Attached image(s) |
rick 918-S |
May 23 2022, 12:42 PM
Hey nice rack! -Celette Group: Members Posts: 20,426 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
tygaboy |
May 23 2022, 12:44 PM
914 Guru Group: Members Posts: 5,274 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Just another 3.6 swap. (IMG:style_emoticons/default/happy11.gif)
Attached thumbnail(s) |
emerygt350 |
May 26 2022, 08:13 AM
Advanced Member Group: Members Posts: 2,079 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Just switched the decel to the right configuration, max vacuum on drag is 23 lbs. I hooked up my vac pump while the car was running and noticed it doesn't really affect engine speed untill maybe 21 pounds even though bench test had it opening at 18.5. anyone try it on the motor? Wondering if I should adjust that .. |
NotLance |
May 26 2022, 10:11 AM
Member Group: Members Posts: 66 Joined: 4-February 21 From: Northern California Member No.: 25,165 Region Association: Northern California |
pencap914 |
May 26 2022, 03:26 PM
Member Group: Members Posts: 75 Joined: 16-April 06 Member No.: 5,872 Region Association: Northern California |
Cairo94507 |
May 26 2022, 03:44 PM
Michael Group: Members Posts: 9,719 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
@tygaboy - Hey that fits remarkably well. (IMG:style_emoticons/default/beerchug.gif)
wonkipop |
May 26 2022, 04:24 PM
Advanced Member Group: Members Posts: 4,250 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
[quote name='pbanders' date='May 23 2022, 07:18 AM' post='3003614']
[quote name='emerygt350' date='May 23 2022, 05:19 AM' post='3003604'] [quote name='emerygt350' date='May 23 2022, 06:05 AM' post='3003602'] [quote name='pbanders' post='3003407' date='May 22 2022, 07:18 AM'] []. Vacuum should be connected to the 5 mm control port (the one with the thread and nut) and to the 9 mm port on the opposite end, and fresh air from the air box should be connected to the 9 mm port on the side. Most diagrams have the connections to the two 9 mm ports reversed. If you connect it that way, the valve cannot work, because there's vacuum on both sides of the internal diaphragm, and it never moves, no matter what the vacuum is in the intake plenum. [/quote] Just to be clear. Vacuum goes to the small port facing the passenger, that is what I have for sure. And vacuum also to the posterior port facing the rear of the car? Wouldn't that create vacuum on both sides? I don't really know what the construction of the valve looks like internally but it just feels like it would... [/quote] Below is a diagram of the internals of the decel valve. As you can see, it's two chambers separated by a flexible diaphragm, and a valve covering the end port. If vacuum is applied to both the control and the side port, and the end port is connected to atmospheric pressure, the diaphragm has the same pressure on both sides and will never move, no matter what pressure is applied. This configuration is the way many of the hose diagrams show. Now, swap the hoses on the side and end port, so that the side port is connected to atmospheric pressure and the end port to vacuum. If P1 is at atmospheric pressure and P2 is at a vacuum below the setpoint, the tension spring will hold the valve shut. Once P2 is at a high enough vacuum to overcome the spring tension, the valve opens, and P1 now cannot exceed the setpoint vacuum, limiting the vacuum - which is why the device is also called a vacuum limiter. BTW, this is not conjecture, I have tested it in both configurations using my hand vacuum pump and hoses and tee connectors to apply vacuum to the ports. You can test it yourself, this is how it works. [/quote] you are correct @pbanders i have seen hose diagrams floating around which have the wrong connections to the ports on the decel valve for 1.8 L-Jets. amongst other hose errors. even the diagrams in the factory workshop manual covering D Jet are questionable. often the decel valve isn't even drawn as an accurate representation with regard to ports. you can find a reliable configuration layout in the parts catalogue. |
friethmiller |
May 26 2022, 04:57 PM
Member Group: Members Posts: 463 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
Cairo94507 |
May 26 2022, 05:53 PM
That's very clean and a nice small compressor. (IMG:style_emoticons/default/beerchug.gif)
pbanders |
May 26 2022, 10:21 PM
friethmiller |
May 27 2022, 08:40 AM
ClayPerrine |
May 27 2022, 11:27 AM
Life's been good to me so far..... Group: Admin Posts: 15,416 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
friethmiller |
May 27 2022, 12:56 PM
Where did you get the AC compressor mount? I am looking for one to use on Betty's car. Thanks! Clay Hi Clay, Check out Doug's A/C thread - http://www.914world.com/bbs2/index.php?sho...192917&st=0. He was instrumental in assisting with my A/C setup. ~Fred |
mlindner |
May 27 2022, 01:48 PM
Senior Member Group: Members Posts: 1,514 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
friethmiller |
May 27 2022, 03:16 PM
Retroracer |
May 27 2022, 03:35 PM
Senior Member Group: Members Posts: 609 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
bkrantz |
May 27 2022, 08:51 PM
914 Guru Group: Members Posts: 7,736 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
2056 with dual ITBs, megasquirt, and electronic ignition (no distributor).
mlindner |
May 28 2022, 09:42 AM
campbellcj |
May 28 2022, 11:40 AM
I can't Re Member Group: Members Posts: 4,542 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
Lo-Fi Version | Time is now: 28th April 2024 - 06:57 PM |
