Dynamat |
Dynamat |
Medtner3 |
May 20 2022, 06:30 PM
Member Group: Members Posts: 180 Joined: 7-July 20 From: Cedar Park Member No.: 24,467 Region Association: None |
Dynamat: What thickness should you use? should you put over the tar on the floor should you throw away the rubber pad behind the backpad on the firewall?
I need some adivce: I want to add sound barrier under my backpad and possibly floor. I currently have the black tar floor, nothing in doors and rubber pad behind backpad which honestly has seen better days and looks pretty nasty. Should I add any sound proofing to the floor before I carpet? If so, what thickness? Also, should I throw out the old cracked and dirty rubber pad and put sound proofing on top of the firewall behind the backpad or leave it as is? Thanks in advance for advice |
FlacaProductions |
May 23 2022, 02:27 PM
Senior Member Group: Members Posts: 1,571 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Maybe something like this - cheaper and lighter than the original...
https://www.rix914parts.com/store/p29/914_F...uction_Mat.html no affiliation. |
Lo-Fi Version | Time is now: 11th May 2024 - 08:22 PM |
