bkrantz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,446 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains ![]() ![]() |
I noticed (and then forgot) this when I first installed the engine, but the rear seal across the vertical sheet metal does not lie close to sealing along the sides. Did I install the rubber upside-down? The shorter flap is on top.
Attached thumbnail(s) ![]() |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,309 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Looks correct but you need to coax the back flap to the Trans side of the R. tin
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,375 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
The engine tin fits between the two flaps, one flap in the engine compartment and one in the transmission section.
Lo-Fi Version | Time is now: 18th July 2025 - 11:09 PM |
