Should we lube wheel bolts?, Tell me tell me... |
JeffBowlsby |
Aug 3 2005, 01:16 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
So my factory 914 repair manual says to lube the ball surfaces of wheel bolts with MoS2 grease. Thats the surface that bears on the wheel bolt cups. MoS2 is molybdenum disulfide I am told (I never took chemistry). (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Does anyone do this? What does the lube do? What is the advantage of it? What happens if its not done? What is MoS2 typcially known as...wheel bearing grease or...and is it available at my FLAPS? |
bondo |
Aug 3 2005, 01:19 PM
The ball cups on my cookie cutters are pretty galled up. I'm guessing some grease would prevent that.
Anyone know how to smooth out the ball cups in alloy wheels? (I was thinking I might try an old lug nut attached to a drill, and some valve grinding compound..) |
Joe Ricard |
Aug 3 2005, 01:28 PM
Yes I lube the lug nuts. Both thread and ball seat.
But I am changing wheels minimum 4 times a month. sometimes more. I have studs and 928 alloy nuts for street and steel nuts for 4 lug Fuchs and race rubber. The diamond wheels tighten up OK with the Steel nuts but cut up the ball seat. Really need acorn nuts. |
MikeP |
Aug 3 2005, 01:50 PM
Member Group: Members Posts: 321 Joined: 13-June 05 From: San Jose, CA Member No.: 4,268 |
for an accurate amount of torque. The torque comes from the threads/bolt stretch not surface friction.
zonedoubt |
Aug 3 2005, 01:57 PM
Canadian Member Group: Members Posts: 668 Joined: 14-May 03 From: Vancouver, BC Member No.: 696 Region Association: Canada |
Molybdenum disulfide is a high-pressure lubricant. One brand name I know of is MolySlip. |
URY914 |
Aug 3 2005, 02:07 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,304 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Lube is good.
Steel grinding against steel is bad. P |
ArtechnikA |
Aug 3 2005, 02:26 PM
yes. prevents galling and sticking. it is an essential ritual if you ever use Porsche aluminum lug nuts; when one of those decides to stick to a wheel stud due to corrosion and eletrolytic migration it is not a pretty sight. provides consistent torque, allows you to subsequently remove the bolts/nuts without damage. picture having to pull a front hub and removing a lug bolt by using a drill and EZ-Out from the backside... moly disulphide is frequently used in anti-sieze compound and assembly lubes, available at the FLAPS. actually, any anti-sieze is better than nothing, but by specifying a MoS2 compound they eliminate a lot of the junk and discourage you from just using plain grease. i like LubroMoly LM-39, but you'll be fine with almost any assembly lube. use latex gloves and have paper towels or shop rags handy; the good stuff will stain. |
jonwatts |
Aug 3 2005, 03:38 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Sammy gave an excellent write-up about bolt lubrication in this thread just a few weeks ago. I think the pearl of wisdom to take away from it is that torque specs imply that the threads are lubricated.
Midtowner |
Aug 3 2005, 04:33 PM
Ooooo! Group: Members Posts: 652 Joined: 21-December 04 From: Sunnyvale, CA Member No.: 3,316 Region Association: None |
Now I know what I'm doing tonight! Thanks! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
J P Stein |
Aug 3 2005, 04:45 PM
I butterfly the sockets on my wheels.....carefully. Takes maybe a minute a hole. |
bondo |
Aug 3 2005, 05:03 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I seriously have no idea what that means. |
LongARM |
Aug 3 2005, 06:15 PM
it's better to burn-out , then it is to rust Group: Members Posts: 222 Joined: 6-March 05 From: Kingston Ontario Canada Member No.: 3,720 |
ot here
Midtowner... would you have some additional pics of that 73 in your avator.. i wanted to see the painted sails... thanx (IMG:http://www.914world.com/bbs2/html/emoticons/hijacked.gif) |
LongARM |
Aug 3 2005, 06:16 PM
and i lube my nuts too. (IMG:http://www.914world.com/bbs2/html/emoticons/ninja.gif)
madd_dogg_914 |
Aug 3 2005, 06:27 PM
Member Group: Members Posts: 478 Joined: 30-March 03 From: Vacaville, CA Member No.: 497 Region Association: Northern California |
My girlfriend takes care of that for me (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
J P Stein |
Aug 3 2005, 06:44 PM
Get an air powered die grinder. (my 2nd favorite tool (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) )
A 1/4 inch rod...bout 4 -6 inches long. Take a hack saw & cut a longitudinal slot in the rod (on center) about 3/4 inch long....then grind smooth taper on the slotted end. Tear off a piece of emery cloth about 2 X 1 inches....fold it in half lengthwise & stick the center of it into the slot(your butterfly) Put that sucker into the die grinder, pull the trigger & shove it into a hole (or ball cup/hole). One can also use a chunk of scotch bright. Any hole you wanna clean up/de-burr. Sheet metal, steel, aluminum & up to about 4 inches in dia. If you really press, I'll take a pic. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
jonwatts |
Aug 3 2005, 07:27 PM
I don't see a smilie for "press" so how about (IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif)
J P Stein |
Aug 4 2005, 08:25 PM
Warning:
Fuzzy pics coming. Here's the tool....and the only gud pic. Attached thumbnail(s) |
J P Stein |
Aug 4 2005, 08:28 PM
Another one I kinda forgot about for the ball socket....it's a scotchbright disc...1" dia IIRC and the pics go to hell.
J P Stein |
Aug 4 2005, 08:29 PM
Worser pic. untouched hole.
J P Stein |
Aug 4 2005, 08:30 PM
Reworked
Lo-Fi Version | Time is now: 2nd May 2024 - 05:17 AM |
