EV 914's |
EV 914's |
raynekat |
Jun 22 2022, 08:58 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Whether you like 'em or not....they are definitely a wave of the future.
Not sure what I think about the whole idea myself. Still have the rear luggage boot which is nice. It's pretty slick the bolt in rear cradle that holds some of the batteries, Tesla motor, cooling, etc. The "custom" look is pretty bad as to me. https://www.youtube.com/watch?v=hJTNsH-SIqk |
wonkipop |
Jun 24 2022, 06:08 PM
Advanced Member Group: Members Posts: 4,301 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
@bbrock - i can see the point @Superhawk996 is making.
at least in relation to the EV conversion in question. they have installed a battery pack in the nose forward of the front axle line. which will change the low polar moment character of the 914 where all major weight was inboard. also the battery pack in the engine bay is vertical so some weight is up at a higher centre of gravity? it might not ruin the 914 but it will change it. the front battery pack location means that things are more like a blend of 924 where major weight was right out to ends of car in line with axles or boxster where they have deliberately put weight out past the axle lines (ie radiators etc) to curb low polar moment snappiness. however in case of both examples porsche took care to have 50 50 weight distribution. if you could set up an ev to maintain that 50 50 weight dist and importantly balanced the right distance from axle lines you might end up with a very neutral handling car closer to a 924 or boxster. but as superhawk says. it isn't a 914 anymore. i think it would very tricky to do an ev conversion on a 914 and keep its particular handling character. ideally the battery packs need to go in the space where the fuel tank once was. and for the power unit and battery packs in engine area to have as low a centre of gravity as possible. |
bbrock |
Jun 24 2022, 07:05 PM
@bbrock - i can see the point @Superhawk996 is making. at least in relation to the EV conversion in question. Oh, I get his point too. I'm just saying ditch the pack in the frunk, move what you can to the gas tank area, and take the hit on range and you are close to where you started on weight distribution. Not exact, but close. To say that an EV conversion ruins the handling of a 914 as a blanket statement is a bit of an overreach IMO. As far as whether it is still a 914, I'd have to drive it before I would make that call. People transplant all sorts of exotic drive trains into these chassis without getting kicked out of the 914 club. Whatever they are, they look like hella fun cars. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 10:25 PM |
