Charles Freeborn |
Member ![]() ![]() Group: Members Posts: 282 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest ![]() |
So, on to the brakes in this new car. It still has the OEM proportioning valve for the rears. As I understand when the brake pressure reaches a certain limit (500 plus psi as I recall) it stops sending fluid to the rear calipers. My first question is does it stop and hold at that psi leaving the rears engaged to that level while allowing fronts to get more input, or does it drop the rears to 0?
The other consideration is to use a manual valve such as the Tilton. If going that route how does one determine settings without chancing spins or other drama? Thanks. |
Lo-Fi Version | Time is now: 10th May 2025 - 11:40 PM |
