It might work better with all the parts in it., I should have pulled the transaxle sooner |
914e |
Jun 26 2022, 12:36 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I knew first and second gear syncros were in bad shape. Third is not bad, reverse has some issues.
First problem no gaskets, it is sealed with rtv, I have know idea what the preload and backlash for the ring and pinion is at his point. I guess I need to check the both. Next I notice the the reverse idler gear thrust washer is badly scored and worn. Thinking to myself I think we are missing a part. Bearings are just extra parts, you don't need those. /s The reverse idler gear does not look badly worn from the thrust washer. However the teeth look pretty beat-up. I think I might need to find a replacement reverse idler gear. I think without the bearing between the reverse idler gear and thrust washer, it was sometime touching the first / reverse shift sleeve. Some syncro rings have the expected wear, but this one has groove in it. it seems to be a manufacturing defect. Some of the brake bands show wear, i'm not sure if that is normal. Some of my syncro hubs look more like igloos than peaked roofs. |
914Sixer |
Jun 26 2022, 05:49 AM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Yep, ugly for sure.
Lo-Fi Version | Time is now: 19th May 2024 - 05:28 AM |
