It might work better with all the parts in it., I should have pulled the transaxle sooner |
914e |
Jun 26 2022, 12:36 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I knew first and second gear syncros were in bad shape. Third is not bad, reverse has some issues.
First problem no gaskets, it is sealed with rtv, I have know idea what the preload and backlash for the ring and pinion is at his point. I guess I need to check the both. Next I notice the the reverse idler gear thrust washer is badly scored and worn. Thinking to myself I think we are missing a part. Bearings are just extra parts, you don't need those. /s The reverse idler gear does not look badly worn from the thrust washer. However the teeth look pretty beat-up. I think I might need to find a replacement reverse idler gear. I think without the bearing between the reverse idler gear and thrust washer, it was sometime touching the first / reverse shift sleeve. Some syncro rings have the expected wear, but this one has groove in it. it seems to be a manufacturing defect. Some of the brake bands show wear, i'm not sure if that is normal. Some of my syncro hubs look more like igloos than peaked roofs. |
Superhawk996 |
Jun 26 2022, 11:19 AM
914 Guru Group: Members Posts: 5,827 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
First problem no gaskets, it is sealed with rtv, I have know idea what the preload and backlash for the ring and pinion is at his point. I guess I need to check the both. Pinion will be marked - procedure to set is in factory manual but requires some special purpose tools to measure and set the ring and pinion properly. The main issue a this point will be that it was running for while without the proper pinion setting (due to the RTV) and the wear patterns on ring and pinion are now established. Setting it yet again back to OEM position will probably result in even more noise and accelerated wear. Given the other issues you have I'd probably just find a new transmission. |
914e |
Jun 27 2022, 01:01 AM
First problem no gaskets, it is sealed with rtv, I have know idea what the preload and backlash for the ring and pinion is at his point. I guess I need to check the both. Pinion will be marked - procedure to set is in factory manual but requires some special purpose tools to measure and set the ring and pinion properly. The main issue a this point will be that it was running for while without the proper pinion setting (due to the RTV) and the wear patterns on ring and pinion are now established. Setting it yet again back to OEM position will probably result in even more noise and accelerated wear. Given the other issues you have I'd probably just find a new transmission. I think it ran for far under a thousand miles set up this way. It was an engineering project and sat for decades. I did not hear any bearing or ring and pinion noise. I should have tools to set up a ring and pinion, it has over 30 years since last set one up. So I'm a bit rusty. My plan is the check the bearing preload, back lash, and the ring and pinion contact pattern, that should show me how much it has worn. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:45 AM |
