> Dual Carb with fuel return line
ndfrigi
post Jun 29 2022, 01:31 AM
Post #21
Hello Teeners! Is there anyone can share any pictures how they do a return fuel line especially on the carb side?
Since I will be replacing my fuel lines to SS and removing my fuel tank to clean, much as well prep everything with return line.
I have Weber 36 Idf with 32vent
Thank you!
ndfrigi   Dual Carb with fuel return line   Jun 29 2022, 01:31 AM
930cabman   I have never ran a return line with a carb setup, ...   Jun 29 2022, 04:54 AM
brant   There is a diagram showing multiple ways to plumb ...   Jun 29 2022, 05:37 AM
brant   Here I’m using B E is a match to how the facto...   Jun 29 2022, 05:49 AM
bbrock   I have mine set up in the stock configuration usin...   Jun 29 2022, 07:27 AM
CCE   I have mine set up in the stock configuration usi...   Jun 29 2022, 08:00 AM
bbrock   I have mine set up in the stock configuration us...   Jun 29 2022, 08:10 AM
GregAmy   Unless the tanks differ, the part in the center is...   Jun 29 2022, 08:33 AM
bbrock   Unless the tanks differ, the part in the center i...   Jun 29 2022, 11:17 PM
Mark Henry   I tried but ran into issues with the small return ...   Jun 29 2022, 08:48 AM
nathanxnathan   I have always used the Holley pressure regulator (...   Jun 29 2022, 08:52 AM
NARP74   Remember OP said carbs. This is a 50/50 6 hour ar...   Jun 29 2022, 08:58 AM
GregAmy   The Webers (and Dells) do not offer an in/out port...   Jun 29 2022, 09:05 AM
Mark Henry   The Webers (and Dells) do not offer an in/out por...   Jun 29 2022, 11:30 AM
bbrock   The Webers (and Dells) do not offer an in/out por...   Jun 30 2022, 07:44 AM
nathanxnathan   I'm running this Malpassi bypass regulator. ...   Jun 30 2022, 10:53 AM
9146C   I just went through an exercise on my 2.7L six (wi...   Jun 29 2022, 10:28 AM
nathanxnathan   The Holley regulator was able to reduce the press...   Jun 29 2022, 11:17 AM
CCE   The Holley regulator was able to reduce the pres...   Jun 29 2022, 11:38 AM
nathanxnathan   In my case I had no need for the regulator, I in...   Jun 29 2022, 11:51 AM
BK911   I vote for option D. With a pmo style regulator.   Jun 29 2022, 10:34 AM
ndfrigi   Thank you everyone for all the responses!   Jun 29 2022, 04:01 PM
Front yard mechanic   Ok I'm an idiot what is the key to the diagram...   Jun 29 2022, 09:14 PM
ndfrigi   Ok I'm an idiot what is the key to the diagra...   Jun 29 2022, 11:39 PM
Front yard mechanic   Ok I'm an idiot what is the key to the diagr...   Jun 30 2022, 06:13 AM
NARP74   Same question for @BBrock and which configuratio...   Jun 30 2022, 11:17 AM
slivel   My configuration is: [*]Tank [*]Filter [*]Pump [*]...   Jun 30 2022, 11:48 AM
bbrock   [quote name='bbrock' post='3012264' date='Jun 30 ...   Jun 30 2022, 11:37 PM
bbrock   Same question for [b]@[url=http://www.914world....   Jul 2 2022, 10:34 AM
- Lo-Fi Version Time is now: 25th May 2026 - 07:38 AM
