Dual 40 IDF's or Dual 34 ICT's?, Finishing up 1.8 engine rebuild |
ghettojet |
Jul 6 2022, 02:29 PM
Newbie Group: Members Posts: 6 Joined: 20-March 22 From: queens new york Member No.: 26,409 Region Association: North East States |
I'm curious what opinions are on how much difference there will be in performance between the dual two barrel Webers and two single barrel carbs?
Totally different machine but had a 72'BMW 2002 that was actually peppier with the original Solex single than the Weber dual I eventually put on it. I sort of figure two singles on a 1.8 should be fine for the streets of Queens and the BQE. Built the motor with a stock cam (I think) and probably around 8.0 compression by my math. Oh and when I was given the car it was basket case completely apart and 90% of FI parts missing so thats kind of out.Oh its a 1974 1.8l car Thanks Sam Queens |
dr914@autoatlanta.com |
Jul 6 2022, 03:11 PM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
install dual 40s anything else (except the original fuel injection!!!!!) will be a waste of time
I'm curious what opinions are on how much difference there will be in performance between the dual two barrel Webers and two single barrel carbs? Totally different machine but had a 72'BMW 2002 that was actually peppier with the original Solex single than the Weber dual I eventually put on it. I sort of figure two singles on a 1.8 should be fine for the streets of Queens and the BQE. Built the motor with a stock cam (I think) and probably around 8.0 compression by my math. Oh and when I was given the car it was basket case completely apart and 90% of FI parts missing so thats kind of out.Oh its a 1974 1.8l car Thanks Sam Queens |
nditiz1 |
Jul 6 2022, 03:12 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
You'll always get better performance out of dual carbs over a single.
Start with Weber 40's stock jetting, AEM AFR meter, Syncrometer (SK), CSP linkage OR tangerine, CB performance rotary fuel pump. Stainless steel fuel line - at least one. |
ghettojet |
Jul 6 2022, 03:23 PM
Ok cool.
Aircooled seems to have the 40 IDF kit available. Thanks very much for your help. Now I've got to search for some posts about what distributor is best. . . . |
nditiz1 |
Jul 6 2022, 04:06 PM
Pertronix svda best bang for the buck next would be the 123, pricey but like tangerines linkage it is the best.
bbrock |
Jul 6 2022, 04:41 PM
I ran dual 34ICTs on a 1.7L for awhile. They worked well for a commuter but you definitely notice a loss of top end. Can't comment much on low end because I was running the horrible 009 dizzy with its notorious dead spot. I think the 34ICTs would have been fine for low end with a better dizzy. If you want your car to scoot, go with the 40IDFs. Someone recently commented that 34ICTs aren't much cheaper than 40IDFs which makes the choice easy. IMO, the best is to go FI, either stock or something modern like Megasquirt. I'm hoping to ditch my 40IDFs for Megasquirt this winter.
ChrisFoley |
Jul 7 2022, 04:04 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I wouldn't use dual ICTs on a T4 unless it was the only available option.
Single Holley carb setups are better imo. |
bbrock |
Jul 7 2022, 07:43 AM
I wouldn't use dual ICTs on a T4 unless it was the only available option. Single Holley carb setups are better imo. This is surprising to hear. I switched to ICTs after not being able to keep the car running with a single Holly carb in cold weather. They were very inexpensive at the time and all I could afford. The ICTs got me to work and back reliably where the Holly could not. The Holly would literally form a coat of ice around the runners. Made the same swap on a VW bus I had at the time for the same reason. |
sportlicherFahrer |
Jul 7 2022, 08:18 AM
Nothing to see here. Group: Members Posts: 1,078 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
For a long time, the stock 1.8L distributor was the hot ticket for carb conversions. Might try running that if you happen to have one.
porschetub |
Jul 7 2022, 05:26 PM
This thread has come up SO many times and I'am surprised that no one has mentioned the Kadron carbs,been on the Kaddie Shack website and they offer a kit for T4 motors,research indicates they should work well and not suffer issues the 34ICT's have which is caused by small throttle bore and small stock venturi's which you can't change or that was the case on a T1 buggy motor I fitted these to ?.
These carbs work pretty well on a small displacement T1 motor as I found out. Downside is the Kadron kit isn't that cheap but by the time you buy a set of IDF's they look like a pretty good solution for a 1.7-2.0 mild engine ?. Food for thought as they say ?,comments welcomed,cheers. |
nditiz1 |
Jul 7 2022, 06:27 PM
I remember one time I ran Kadrons on my beetle...
I'd run Chinese knock off idfs before I'd run kadrons. |
CCE |
Jul 7 2022, 10:17 PM
CCE Group: Members Posts: 309 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
I leave in Mexico City in the high part of the city by the mountain. Elevation: 2586m / 8484feet, will a 40mm dual carb work better than the 44mm?
(IMG:style_emoticons/default/blink.gif) Not as much oxygen here as I would like. ( I think the more Air the better) I Have a bored 2.15L ported balanced motor with ported redline manifolds and 44mm webers, looking forward to install the CB performance conical trumpets which I was told will do a better job here too.. I also installed the CB performance ignition which has worked fine so far. (Less than. 500miles on them, I know too soon to tell, but it works) |
porschetub |
Jul 9 2022, 02:00 PM
I remember one time I ran Kadrons on my beetle... I'd run Chinese knock off idfs before I'd run kadrons. (IMG:style_emoticons/default/agree.gif) I was only mentioning the Kadrons as a better option than the ICT's. |
maf914 |
Jul 9 2022, 02:42 PM
CCE |
Jul 11 2022, 02:02 PM
I also installed the CB performance ignition which has worked fine so far. (Less than. 500miles on them, I know too soon to tell, but it works) CCE, What type distributor are you using? It does not look like a Bosch. Cb performance, it comes with a kit, it does multy spark fires and eliminates spark miss-fire by just blowing it all up! Several times. With a lot of power. That is my not specialist approach… No points anymore. Which is also a bonus. I had the bosch but after I started firing the car just did not want the hassle. I had the Petronics one also, but liked more the aftermarket look of the CB Performance. I think they work the same, and just why suffer. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:11 PM |
