Exhaust limits |
Exhaust limits |
FJ1200 |
Jul 15 2022, 11:56 AM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
Happy Friday,
I don't post here very often (crazy work schedule). I am considering engine options for my 72 this winter. It is currently, basically a bus 2.0 with a web 86 and 42x36 bus heads and 40 IDF's. I am contemplating throwing a set of 96mm jugs with flat tops in it this winter. I am also thinking about a set of new AA heads. The type 4 store stuff is beautiful but currently way outside my budget. The car has SSI 2.0 HE's with a Brush system. During this work I would like to get the heat functional again (I live in Maine). Is 125hp and comparable torque reasonable from what I talking about? Or who knows, maybe a little more. The lower end has about 20k on it, was lined bored and is oil tight and makes no "odd" sounds. Thanks for any input. Dan |
mrholland2 |
Jul 15 2022, 02:23 PM
Senior Member Group: Members Posts: 750 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
Happy Friday, I don't post here very often (crazy work schedule). I am considering engine options for my 72 this winter. It is currently, basically a bus 2.0 with a web 86 and 42x36 bus heads and 40 IDF's. I am contemplating throwing a set of 96mm jugs with flat tops in it this winter. I am also thinking about a set of new AA heads. The type 4 store stuff is beautiful but currently way outside my budget. The car has SSI 2.0 HE's with a Brush system. During this work I would like to get the heat functional again (I live in Maine). Is 125hp and comparable torque reasonable from what I talking about? Or who knows, maybe a little more. The lower end has about 20k on it, was lined bored and is oil tight and makes no "odd" sounds. Thanks for any input. Dan My gentle suggestion is to remove that single carb and throw it away (or sell it, or use it as a paperweight). The extremely long runners cause a temperature drop and fuel falls out of suspension. This can cause fuel wash in the cylinders and excessive wear. |
FJ1200 |
Jul 15 2022, 02:32 PM
I dont have a single carb, it has twin 40's that I worked over and have the jetting pretty near spot on. The car runs great, economy seems good. Hard to say the odometer id kaput.
Van B |
Jul 15 2022, 06:44 PM
Senior Member Group: Members Posts: 1,586 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
What’s the question here exactly?
FJ1200 |
Jul 15 2022, 06:56 PM
Basically, what are the hp/tq limits of the stock 2.0 heat exchangers?
Van B |
Jul 15 2022, 07:21 PM
Oh, yeah way higher than what that motor will make. Especially with the organized flow you get from the collectors on the Bursch
emerygt350 |
Advanced Member Group: Members Posts: 2,096 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I don't think the headers should be any kind of restriction till you hit close to 200hp. It's the fricking banana that sucks.
Van B |
Jul 15 2022, 07:22 PM
OEM primary size on a 996/997 is 1 5/8” (40mm) and they’re 300-350hp motors
porschetub |
Jul 15 2022, 11:09 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Happy Friday, I don't post here very often (crazy work schedule). I am considering engine options for my 72 this winter. It is currently, basically a bus 2.0 with a web 86 and 42x36 bus heads and 40 IDF's. I am contemplating throwing a set of 96mm jugs with flat tops in it this winter. I am also thinking about a set of new AA heads. The type 4 store stuff is beautiful but currently way outside my budget. The car has SSI 2.0 HE's with a Brush system. During this work I would like to get the heat functional again (I live in Maine). Is 125hp and comparable torque reasonable from what I talking about? Or who knows, maybe a little more. The lower end has about 20k on it, was lined bored and is oil tight and makes no "odd" sounds. Thanks for any input. Dan Mentioned later on you will be fine with current exhaust,bus heads with big valves ?could work but when the oversize valves were fitted was there any work done to improve flow in the ports? , these heads are cast for torgue in port size unlike the 914 heads with are for more power, so you could really have a limit there. Appears the 1.8 914 head is a go to for flow of the EFI motor. HP numbers are subjective really dependant a shitload of things but you should easily get over 100+hp with a 2056 and more with everything dialed in,cheers |
porschetub |
Jul 15 2022, 11:18 PM
Van B |
Jul 15 2022, 11:24 PM
OEM primary size on a 996/997 is 1 5/8” (40mm) and they’re 300-350hp motors Yes but that is a 6 cylinder and the tech in these motors has little to do with a T4 motor. I wouldn’t over complicate it. Flow is flow… moving a mass of gas through a volumetric space. |
ChrisFoley |
Jul 16 2022, 03:44 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Your exhaust is good to at least 140hp. It's not hard to reach that hp with a 2056, but extracting more power than that takes more cam than a Web86 with 96mm P&Cs.
barefoot |
Jul 16 2022, 07:51 AM
Senior Member Group: Members Posts: 1,274 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Switching to 2.0 heads will loose you compression ratio, they're 60cc vs bus heads of 48cc. If you've got big valves, not much to gain ??
FJ1200 |
Jul 16 2022, 08:56 AM
So, the long and the short of it is. Stock 2.0 heat exchangers + bursch exhaust can make upwards of 140 hp and I would assume similar torque. As far as compression goes, I have to believe getting in the region of 9.0 - 9.5 : 1 would be a huge improvement. My leak down numbers are around 10% but yet static compression is only about 100 psi. Any experience with the AA replacement 914 2.0 heads? If I aim to shoot for the upper limits of the exhaust it sounds like a new cam is in order. Now we have content creep. If I am going to split the case, it really is starting to make sense to bite the bullet and do a 2270. I know the type 4 store stuff is kind of the benchmark, but I just can't swing their prices. What are peoples experience with other vendors. If I go down this road I am looking at p/c, crank, cam and heads. I think my credit card just winced in pain.
Dan |
rhodyguy |
Jul 16 2022, 01:14 PM
Project creep. Was case machine work done during the last build? How much power do you feel you MUST achieve? Not the dream number. Power costs. Plenty. Adding 50- 60% more power stresses the other older components. Like CVs, transmissions, clutches, motor mounts.
FJ1200 |
Jul 16 2022, 01:44 PM
I have the invoice from the last engine build. The case was line bored. As far as oil galley plugs and the like, I am not sure. I would be happy with 130-140 hp, not looking for a high rpm motor. 90% of the driving is commuting on secondary roads in Maine. Phase 2 of this (next winter) will be standalone EFI with twin IDF throttle bodies and a waste spark ignition system. I don't mind carbs, I am very good with them but as an almost daily driver I get tired of weberitis and having to "tweak" them every 4-6 weeks. Nothing scares me work wise. I was a Porsche/Audi shop foreman for 20+ years and I am a hobby machinist with a Bridgeport, lathe and the like.
Jul 16 2022, 02:46 PM
Even if you do not build out the engine, get the heat working. It will greatly extend your driving season and comfort and driving with the top off on a cold day while the heat is on almost feels like cheating. If you need any parts besides the heat exchangers, let me know. If I have them, you can have for the cost of shipping. (IMG:style_emoticons/default/beerchug.gif)
FJ1200 |
Jul 16 2022, 03:22 PM
Thanks mepstein! I think I have most everything. I need the obvious all new paper tubes. Another project for this winter is to pull the tank, go through the heater box, service the wiper assembly (slow) and replace anything that fuel passes through. I should probably service the two heater valves in the engine bat while I'm at it. It still has the polyamide lines (fingers crossed), Mainly I need a defroster, I work at Bath Iron Works were we build the Arleigh Burke class destroyers. The dew point always seems to be around 60 deg, I come out from 2nd shift at midnight and the inside of the windshield is fully fogged. I will admit that I am guilty, often I leave the roof in the garage, so I don't seal it up.
Jul 16 2022, 03:31 PM
I’m a big fan of Tangerine Racing SS lines. 5 minutes when your engine is out of the car.
Rain-X on your windshield will help. |
emerygt350 |
Jul 16 2022, 03:35 PM
I wonder if there isn't a cheater heater you could use in the fresh air box. The exchangers are neat and all, but just a little electric heater in the fresh air box would probably work just as well without all the fuss. Anyone try something like that?
Lo-Fi Version | Time is now: 17th May 2024 - 12:24 AM |
