high idle, 3000rpm idle |
slotty008 |
Jul 24 2022, 03:29 PM
Member Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None |
Hi guys ,
I just hope that someone could help us with the idle of my '75 2.0. I have the car for almost 7 years now and idle was always a little bit too high. We have been trying to correct this but it got worse instead of better. We changed the distributor to a 123 ignition, we changed all the vacuumlines, the AAR has been cleaned out and the idle screw is completely closed. The car starts at 1600rpm when cold and once it is warm it goes to 3000rpm and the idle stays there. The car pulls very well , a lot better better than when I just had it. (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
StarBear |
Jul 29 2022, 04:52 PM
Senior Member Group: Members Posts: 1,847 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
AARs are available. One sold here just a few days ago. Big thread on testing and maintaining the a few weeks ago. If can find, also indicates comparable Nissan part #.
Lockwodo |
Jul 29 2022, 05:14 PM
Member Group: Members Posts: 199 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
AARs are available. One sold here just a few days ago. Big thread on testing and maintaining the a few weeks ago. If can find, also indicates comparable Nissan part #. (IMG:style_emoticons/default/agree.gif) best to replace the AAR. It progressively closes as an internal heating element warms up, versus an electric valve would be open or closed. You can also take an AAR apart and may be able to free up the mechanism. There's a you tube video on that. |
slotty008 |
Jul 30 2022, 02:05 AM
AARs are available. One sold here just a few days ago. Big thread on testing and maintaining the a few weeks ago. If can find, also indicates comparable Nissan part #. (IMG:style_emoticons/default/agree.gif) best to replace the AAR. It progressively closes as an internal heating element warms up, versus an electric valve would be open or closed. You can also take an AAR apart and may be able to free up the mechanism. There's a you tube video on that. I've seen the youtube video. I cleaned out the AAR a couple of months ago and it closed when I put current on it. My mechanic already took apart the AAR 2 times several weeks ago,apparently with no result. We'll see next week when the throttle is repaired. (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/unsure.gif) |
wonkipop |
Jul 30 2022, 02:55 AM
Advanced Member Group: Members Posts: 4,239 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
AARs are available. One sold here just a few days ago. Big thread on testing and maintaining the a few weeks ago. If can find, also indicates comparable Nissan part #. (IMG:style_emoticons/default/agree.gif) best to replace the AAR. It progressively closes as an internal heating element warms up, versus an electric valve would be open or closed. You can also take an AAR apart and may be able to free up the mechanism. There's a you tube video on that. I've seen the youtube video. I cleaned out the AAR a couple of months ago and it closed when I put current on it. My mechanic already took apart the AAR 2 times several weeks ago,apparently with no result. We'll see next week when the throttle is repaired. (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/unsure.gif) yes @slotty008 - i've got a theory on these old AAVs and them seeming to work when you test them. i will qualify this by saying mine is a 1,8 L jet which has a different design of AAV mounted directly on the engine block. i cleaned and tested mine 2.5 years ago and yes it seemed to work. but what i have retrospectively thought is that i had it out of the car and i tested it on a bench. i now wonder if the cold engine block conducted cold into the body of the AAR means that when installed on the engine, and with an age weakened spring that it just can't warm up and close like it did new. so it sort of sits there. in fact in my case its jammed closed. i did have a really weird thing happen about 2 weeks ago when it actually worked. thats because here in australia we have been having record cold temps. somehow i think it was so cold that it caused the AAV to contract open past some point it had been sticking at - maybe due to a small ridge of corrosion. they are very fickle at this point in time half a century down the track. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 23rd April 2024 - 06:26 AM |
