Volt meter question, Secondary added question |
Menmojo |
Jul 26 2022, 08:14 PM
Porsche addict Group: Members Posts: 49 Joined: 7-July 15 From: Midwest Member No.: 18,929 Region Association: None |
I’m working on a 1975 914. I just replaced a non working volt meter with a working period correct vdo volt meter. When the car is shut off the volt meter is reading the voltage.
Is this correct? Is the volt meter supposed to be switched on with the ignition or does it always show the voltage? I’m concerned that it will slowly drain the battery. The car has the stock wiring harness and originally came with a center gauge package. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:39 AM |
