facet fuel pump, which one? |
doobie123 |
Aug 2 2022, 05:17 PM
Member Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi all,
i'm working on a 1975 914, 1.8. there is a facet fuel pump in the car that needs replacimg. i wanted to order one from auto atlanta, (great place by the way) but they have discontinued them. looking on mine, i can't find a model number. anyone out there know which one is the correct one? thanks |
nditiz1 |
Aug 2 2022, 05:40 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
hi all, i'm working on a 1975 914, 1.8. there is a facet fuel pump in the car that needs replacimg. i wanted to order one from auto atlanta, (great place by the way) but they have discontinued them. looking on mine, i can't find a model number. anyone out there know which one is the correct one? thanks I'm going to assume you are running carbs? |
SirAndy |
Aug 2 2022, 06:02 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
anyone out there know which one is the correct one? There is no correct one since no 914 ever came with one. When i had my carbed 2056, i ran a CB Performance rotary pump which was much, much quieter. https://www.cbperformance.com/product-p/3193.htm (IMG:style_emoticons/default/smile.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.cbperformance.com-179-1659484940.1.jpg) |
bbrock |
Aug 2 2022, 06:06 PM
I think Facet pumps were outlawed under the Geneva Convention against torture. (IMG:style_emoticons/default/wacko.gif)
nditiz1 |
Aug 2 2022, 06:10 PM
@sirandy - that's where I was going with that, this is probably the best pump to run whether you are in a 4 or a 6 and have carbs.
URY914 |
Aug 2 2022, 06:16 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,147 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Andy is spot on. (IMG:style_emoticons/default/beerchug.gif)
mb911 |
Aug 2 2022, 06:51 PM
914 Guru Group: Members Posts: 6,810 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
@sirandy - that's where I was going with that, this is probably the best pump to run whether you are in a 4 or a 6 and have carbs. Yup I run the same one. |
theer |
Aug 3 2022, 07:21 AM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
I agree with the others on fuel pumps- I have the same on my carbed 1.9l, but I do have a Facet pump you can have for the cost of shipping, if you’re just trying to get it running.
The Facet I have will only work for carbs, by the way. FI needs much higher pressure and a return line. |
930cabman |
Aug 3 2022, 07:39 AM
Advanced Member Group: Members Posts: 3,000 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
has anyone used the Mr Gasket 3psi pump?
rhodyguy |
Aug 3 2022, 08:47 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Remember to purchase a fuel pressure regulator when you buy the facet. Figure out a way to isolate the pump if mounted on a metal surface. The rattling is very annoying.
Ansbacher |
Aug 3 2022, 01:20 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Two questions:
Why are they still manufacturing freaking Facet Fuel Pumps! ??? Why are people still buying them??? Ansbacher |
parrish911 |
Aug 3 2022, 01:47 PM
Newbie Group: Members Posts: 35 Joined: 27-April 06 Member No.: 5,939 Region Association: South East States |
In my humble opinion, best to run a rotary pump, a fuel pressure regulator (I used the one from PMO) and a return line. I did this with a dual carb set-up (40 IDF)
dr914@autoatlanta.com |
Aug 3 2022, 03:17 PM
914 Guru Group: Members Posts: 7,816 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we have them under a different part number now r90160810600
hi all, i'm working on a 1975 914, 1.8. there is a facet fuel pump in the car that needs replacimg. i wanted to order one from auto atlanta, (great place by the way) but they have discontinued them. looking on mine, i can't find a model number. anyone out there know which one is the correct one? thanks |
Dave_Darling |
Aug 3 2022, 10:57 PM
914 Idiot Group: Members Posts: 14,981 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
doobie123 |
Aug 5 2022, 05:25 PM
hey ya'll thanks for the replies.
so i'm thinking that the thing to do is ditch the facet and go with the rotary. got it! thanks for helpin the new guy out! |
SKL1 |
Aug 5 2022, 11:12 PM
Senior Member Group: Members Posts: 1,597 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Definitely the rotary pump as mentioned, and a fuel regulator.
(and we don't need another 10 page thread carbs vs FI) |
Lo-Fi Version | Time is now: 24th April 2024 - 07:18 PM |
